Somethings out of place
Old Feb 15, 2011 | 09:35 PM
  #111
ramario99's Avatar
ramario99
Yesterday I got it to run again.
It happens like this,
I turn on the Ram.
let it idle in P (If I rev it it starts to bog and misfire BAD)
Shift it to N, extra ****ty idle, almost dying (rev it and its FINE!- no misfires)
shift it to D and start peeling the tires (this is the only way I can get it to work)
Shift it to R and do the same thing.
Now I can drive it around with no problems.
If im on a red light for a while, it'll stall
Old Feb 19, 2011 | 10:48 PM
  #112
ramario99's Avatar
ramario99
bump.
Old Feb 19, 2011 | 11:23 PM
  #113
Any codes?
Old Feb 21, 2011 | 03:19 PM
  #114
ramario99's Avatar
ramario99
I haven't scanned it recently.
could it be lack of transmission oil?
crankshaft pos sens?
Old Mar 5, 2011 | 04:45 PM
  #115
ramario99's Avatar
ramario99
It makes me wonder why it'll work after a couple of minutes driving it.
anyone? Im stuck and really need this truck runing. The help
would be very much appreciated
Old Mar 5, 2011 | 08:23 PM
  #116
aim4squirrels's Avatar
aim4squirrels
I would get the FSM out and see what sensors are used in open loop warm up and start trouble shooting each one.
After warm up, the PCM uses the O2 sensor to help determine fuel needs. Id start by checking all sensors relating to fuel and air metering, if you've ruled out spark production.
Id also have the battery checked just to rule it out.
Old Apr 30, 2011 | 01:10 PM
  #117
ramario99's Avatar
ramario99
the Crank Position Sensor was the culprit.
Changed it and now it purrs like a tiger.
The old sensor seemed to be scratched
Old Dec 29, 2011 | 02:29 PM
  #118
ramario99's Avatar
ramario99
It seems im still not done with this truck :P
Another push rod went through the rocker arm. I
am now gonna change all the rocker arms push rods and lifters.
I have removed the Intake manifold and valve covers
Old Dec 29, 2011 | 02:31 PM
  #119
zman17's Avatar
zman17
Retired Moderator - RIP
Get some Harland Sharp 1.7 roller rockers.
Old Dec 29, 2011 | 03:11 PM
  #120
Pushrods go thru rockers for one reason, and one reason only. Lack of lubrication.
