Oil Pan
Old Dec 5, 2010 | 03:40 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Default Oil Pan
My oil pan is so badly rusted that it has numerous pin holes and is leaking badly. I thought the front seal or rear main was leaking, but that is not the case. I am inquiring to someone here about getting a factory replacement. However, I was just wondering if there was something better then the OEM or a Spectre(which is all I see for replacement online) . And if anyone had any ideas of some kind of coating to put on it, IE rhino liner or undercoating..
Old Dec 5, 2010 | 03:45 PM
Spectre is all I came up with as well.....
Wonder if POR15 would be a good saver? I have seen frames coated with it, and you can whack it with a hammer, and not even scratch it.
Old Dec 5, 2010 | 03:56 PM
DukesOfHazzard's Avatar
DukesOfHazzard
http://www.milodon.com/oil-pans/off-...pans-chrys.asp gawd dang it fill out your fricking sig and search already j/k.... would this work? or grind the paint off and use good ole JB WELD, junkyard if not punctured, or tack weld away....
zman17's Avatar
zman17
Nothing is going to save it, it's bad.
Old Dec 5, 2010 | 04:00 PM
DukesOfHazzard
what!? not even duct tape
Old Dec 5, 2010 | 04:06 PM
zman17's Avatar
zman17
Nope, not even duct tape is going to work. LOL It's so bad in some spots, that if I push my finger hard enough it would without a doubt go right through. I saw this coming last couple oil changes, and should have gotten a new pan by now .
Old Dec 5, 2010 | 04:10 PM
DukesOfHazzard
yeah sounds like it, would hate to chance it being that bad , almost sounds like yaks truck
Old Dec 5, 2010 | 04:18 PM
zman17's Avatar
zman17
Not the body, but that is exactly what the oil pan looks like.
Old Dec 5, 2010 | 04:23 PM
DukesOfHazzard
WOW!! $311.89 for a oil pan plus the extras you gotta get with it , are the oil pans the same for the LA block and magnums? which pan is the milodon for? way to much for me either way
Old Dec 5, 2010 | 04:57 PM
EndIsNear's Avatar
EndIsNear
Hughes engines has a new oil pan for $100... and somebody makes a coating for fuel tanks that could work to coat the inside...I think its called "lizard skin"
