Trouble trifecta
Old Dec 5, 2010 | 10:43 PM
bseeton1's Avatar
bseeton1
Default Trouble trifecta
Codes 121 tps volts don't match map
743 tcc solenoid/ circuit
1765 transmission 12v supply relay control circuit
I smell a pattern. Symptoms are shift between od and final drive gear at highway speeds. Any suggestions?
Old Dec 6, 2010 | 02:24 AM
03neonSE's Avatar
03neonSE
I have seen the TPS mess with other sensors. TPS do go bad from time to time.
Old Jan 10, 2011 | 07:49 PM
bseeton1's Avatar
bseeton1
replaced tps and iac fixed idle issues. still kickin in and out of final od at highway speeds??
Old Jan 10, 2011 | 11:55 PM
03neonSE's Avatar
03neonSE
How is your fluid level? Is the CEL still on?
Old Jan 11, 2011 | 12:17 AM
dhvaughan's Avatar
dhvaughan
just guessing here. look in the pdc box beside the battery and see if there is a relay for the trans. swap it with the horn or wiper and reset the pcm by disconnecting negative battery cable and turning on headlights for 30 sec.
Old Jan 11, 2011 | 12:27 AM
bseeton1's Avatar
bseeton1
ill give that a try firstthing in the am
Old Jan 11, 2011 | 12:28 AM
bseeton1's Avatar
bseeton1
fluids good........ cel????
Old Jan 11, 2011 | 10:07 AM
Check Engine Light.
Old Jan 11, 2011 | 11:06 AM
bseeton1's Avatar
bseeton1
no cel ever....... just driving condition changed and as a result of course i checked the codes
Old Jan 11, 2011 | 11:09 AM
Is it actually downshifting, or is the TCC just dancing?
