Still having transmission OD troubles...
Old Dec 7, 2010 | 08:25 PM
EndIsNear's Avatar
EndIsNear
Originally Posted by J415
If your tranny was rebuilt 15000 miles ago, can't you just take it back to the shop that rebuilt it?
Well, I would. But I don't live there anymore. Took it back a few times for other issues before I moved, but this one was never fixed.
Old Dec 8, 2010 | 07:45 PM
EndIsNear's Avatar
EndIsNear
Well, I have another idea that a friend at work brought up to me is like to address to you guys for your input. He had a Ford a while back that he had put a high flow muffler on. Well, it decreased his back pressure and caused his truck to lack vacuum. I have an AeroTurbine AT3030 straight-thru muffler. Could this be a possible reason for my problem?
Old Dec 8, 2010 | 08:19 PM
No. Won't have anything to do with it. The trans is not vacuum modulated in any way shape form or manner. (at least, not to the extent that being on cruise or not will make any difference at all.)
O/D is controlled by the computer. As is the cruise control. I wonder if this isn't a programming issue? If you could slap a tuner onto it, and see if it worked any better, would be interesting......
Old Dec 8, 2010 | 10:31 PM
EndIsNear's Avatar
EndIsNear
I have a superchip on towing mode right now. It did it on performance and 87 octane modes too. I'll try returning it to stock tomorrow to see of it does anything
Old Dec 9, 2010 | 10:59 AM
EndIsNear's Avatar
EndIsNear
Well, turned the superchip back to stock and the problem still persists with excessively low power
Old Dec 9, 2010 | 11:44 AM
I wonder if you don't have a small leak in the cruise servo, causing it to slowly back off the gas? Will your tuner allow you to monitor TPS values while in cruise mode?
Old Dec 9, 2010 | 12:37 PM
EndIsNear's Avatar
EndIsNear
no, mine won't. I tried my bosses auto scanner and it wouldn't either.
Old Dec 9, 2010 | 12:50 PM
Wonder if you could beg/borrow/steal one from the local autoparts store for a bit? The advance auto here has scanners that are capable.... something to check into anyway.
Old Dec 9, 2010 | 01:04 PM
DukesOfHazzard's Avatar
DukesOfHazzard
errrr uggghhhhhh dont use crusie control? i know smart *** reply, seems like i have issues with the tranny sometimes in CC TPS was the first time then acted up a year or two after like it was the TPS again so i just stopped using CC alltogeather........
Old Dec 9, 2010 | 01:45 PM
EndIsNear's Avatar
EndIsNear
Lol if I didn't have to drive so much everyday I wouldn't care. But I tried checking the tps with a voltmeter and the numbers weren't to spec as per Haynes manual. So ill try a new tps tonight and see what happens.
