vibration/grinding
Old Dec 9, 2010 | 12:23 PM
  #21
Jamie71's Avatar
Jamie71
ok, I appreciate the help and I will check everything out
Old Dec 9, 2010 | 12:49 PM
  #22
Jamie71's Avatar
Jamie71
Should the vacuum shift motor move up and down or just be secure and not move at all, i just wonder if that would cause anything or problems.
Old Dec 9, 2010 | 01:01 PM
  #23
Externally, it shouldn't move AT ALL. There is a shaft the vacuum motor moves, but, unless/until you take the cover off, you shouldn't be able to see it.
Old Dec 9, 2010 | 01:12 PM
  #24
Jamie71's Avatar
Jamie71
Cause when i tried to take the cable off the vacuum shift motor the whole thing moves up and down like a loose tooth does
Old Dec 9, 2010 | 01:39 PM
  #25
Time to replace it, and I suspect you just found the cause of your issues.
Old Dec 9, 2010 | 01:41 PM
  #26
Jamie71's Avatar
Jamie71
I hope that will be the problem, you guys sure do know alot on here. I appreciate all the help, i love my dodge and there is alot of work to be done on it.
Old Dec 9, 2010 | 01:42 PM
  #27
yeah, my truck seems to have an EXTREMELY large money absorption cross-section......
Old Dec 9, 2010 | 01:45 PM
  #28
Jamie71's Avatar
Jamie71
mine too, but I love my truck.
