idle sensor
Old Dec 11, 2010 | 02:26 PM
byronpen's Avatar
byronpen
Default idle sensor
ok everyone is saying that there is not one, so here is a picture
Old Dec 11, 2010 | 02:37 PM
byronpen's Avatar
byronpen
Default idle sensor
were is it located
Old Dec 11, 2010 | 02:50 PM
chrscott's Avatar
chrscott
Idle Air Controller.
Back of the Throttle Body.
Remove it, clean it, clean out the "port" that it sits in, reinstall. This is best done with the TB removed. Do not bend or move the plunger/pintle.
When you have the TB off, look down into the intake manifold for pools of oil, especially in the corners.
Make sure to use a new gasket when you reinstall the TB, and lube the IAC o-ring with a little oil when you reinstall the IAC.
Old Dec 11, 2010 | 03:39 PM
byronpen's Avatar
byronpen
can some one point me to a throdel body gasket on the new, for a 1999 dodge ram 1500 4x4 5.9l
Old Dec 11, 2010 | 05:49 PM
Parts store where you get the IAC motor from should carry them. If you are ordering online, just search for throttle body gasket.
Not a sensor. That's why folks are saying there isn't one. Its a stepper motor.
Old Dec 11, 2010 | 11:45 PM
loneriderty's Avatar
loneriderty
on the 5.2's i know have the iac motor but on the side of the intake manafold their is a iac sensor
Old Dec 12, 2010 | 12:36 AM
rond97sport's Avatar
rond97sport
there is no iac sensor .it is a map (manifold absolute pressure)sensor .
Old Dec 12, 2010 | 06:57 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The sensor on the side of the manifold, is an IAT Intake Air Temp sensor.
Old Dec 12, 2010 | 12:06 PM
rond97sport
oops my bad map is on the tb.lol
