Front brakes, want to lock them up....
Old Jun 9, 2012 | 11:10 PM
  #21
Did you bench bleed the M/C before installation? That is a critical step.
Old Jun 9, 2012 | 11:16 PM
  #22
vsraptor's Avatar
vsraptor
Yes I did.
Old Jun 9, 2012 | 11:21 PM
  #23
Cool.
You could try the 'finger method' of bleeding as well. (requires a helper.) Park helper in drivers seat, start at passenger rear (as noted), open the bleeder, stick your finger over the end of it, have helper pump pedal. Pressure will push your finger out of the way, but, your finger over the end of the bleeder will prevent it from sucking air. Watch the level in the M/C CAREFULLY, it's really easy to run it dry this way. Have helper keep pumping (within reason, remember your fluid level) until all you get is fluid. Close the valve, move on to the next one. Once you have gone all the way around the truck, pump up the pedal, and see how it feels. Start the truck, and make sure you have good pedal height. if not, start at the right rear, and do it all again.
Old Jun 10, 2012 | 12:26 PM
  #24
vsraptor's Avatar
vsraptor
5 trips around the truck and still same. I guess replace rubber lines ? Booster?
Old Jun 10, 2012 | 12:29 PM
  #25
vsraptor's Avatar
vsraptor
ALL I want to do is lock up the brakes when I really NEED to!!!! Instead I roll another eight feet when I slam on the pedal at 50mph!!!!
Old Jun 10, 2012 | 12:49 PM
  #26
Recheck the rear brake adjustment.
Will the brakes pump up with the engine running??
Old Jun 10, 2012 | 01:13 PM
  #27
vsraptor's Avatar
vsraptor
The rear brakes were adjusted to the point the drum wouldn't go on and the backed down abit. Yes the pedal pumps up A bit with the truck running but the engine "bogs" down. ?!?...
Old Jun 10, 2012 | 01:16 PM
  #28
Adjust the rears with the drums in place.... Did you have the drums turned by any chance?
The pedal pumps up "a bit"? If you can't pump the brakes up to the point where you only get an inch or three of pedal travel before the brakes start working, the rears are still way out of adjustment, or, you got a bad master cylinder. (or there is a leak somewhere in the system.......)
Does the pedal feel spongy still? Or does it feel solid once pumped up?
Old Jun 10, 2012 | 01:30 PM
  #29
vsraptor's Avatar
vsraptor
So with the drums in place how will I know when to stop? No the drums haven't been turned. When I bench bledd mc, I pumped untill I couldnt pump no more with no movement.
Old Jun 10, 2012 | 01:56 PM
  #30
With the drums in place, turn the adjuster wheel a bit, try and roll the tire, (rear end jacked up obviously. ) You want the shoes JUST touching the drums. Just a wee bit of resistance to turning.
