Front brakes, want to lock them up....
Old Jun 10, 2012 | 02:04 PM
  #31
zman17's Avatar
zman17
Retired Moderator - RIP
With the rear off the ground as HeyYou stated. Tighten the adjusters pretty tight(a couple extra turns), after you can't rotate the wheel(this will center the shoes) Then back the adjuster off until the wheel rotates with a little resistance, as HeyYou also stated.
Old Jun 10, 2012 | 02:09 PM
  #32
Use two screwdrivers to back the adjuster off... use one to push the self-adjuster out of the way, so you CAN turn the adjuster back a bit.
I usually just adjust 'em up, step on the pedal a couple times, then recheck adjustment.
Old Jun 10, 2012 | 03:22 PM
  #33
vsraptor's Avatar
vsraptor
And if the access hole is not opened?
Old Jun 10, 2012 | 03:48 PM
  #34
vsraptor's Avatar
vsraptor
Old Jun 10, 2012 | 04:10 PM
  #35
zman17's Avatar
zman17
My 98 had no hole either. I used a 1/4" angle die grinder and made 2 slots.
