drum brake advice
![Wink](https://dodgeforum.com/forum/images/smilies/wink.gif)
as said, note that the front side and rear side are different lengths. i think the shorter ones are on the front side, or maybe its the long ones, i never can remember.
take a picture of each side before removing all that crap. it might come in handy. there's some pictures in the haynes manual and the 01 service manual, but they're not very clear and detailed.
i generally replace the wheel cylinders to avoid leaks.
adjust the shoes up snug when complete.
Yea, some kind of high temp grease should work. And also adjust your parking brake when your done. It'll have a bit of slack. Gonna be a pain removing the drum for the first time. So have a rubber mallet ready.
Trending Topics
Few do..... Just use a big hammer. if it doesn't wanna come off, whack it with the hammer, turn it some, whack it again, turn it some.... until it pops, then you can just slide it off. (at an angle, on the outer rim of the mounting face.)
Shorter shoes go in front. (they are self energizing.....)
Get the drums turned, any automotive machine shop, and most auto shops should be able to do it up for ya. runs anywhere from five bucks, to 20 bucks each....... Needs to happen though. Bite the bullet, get 'em turned.
Going with new hardware kits is a good plan.
Wheel bearing grease works fine.
Be prepared to buy additional items. When I did mine, I found out that the previous owner didn't take care of them, so I had to buy extra parts for the parking brake. And make sure that your auto parts store actually understands what kind of parts you need. Those two things put me in a bind for a day or so.
Otherwise it was a pretty smooth job.
P.S. The BIGGER the Hammer the Better
