cold weather and door latches
Old Dec 14, 2010 | 11:17 AM
Eberron's Avatar
Eberron
Default cold weather and door latches
Hey guys, here is a question for those of you who also live in cold climates.
When it is very cold out, around -40 or so, the doors are VERY hard to close, you have to slam them so hard I am worried I will end up shattering the window. I am assuming that it's just because of the lubricant in the latches freezing up and being way too stiff/sticky when it's that cold so it can't move properly.
Does anyone else have the same problem? Have you found a solution? I have been thinking of maybe trying some kind of dry lubricant which I really don't know much about, but am open to any other suggestions.
Eb.
Old Dec 14, 2010 | 11:26 AM
J415's Avatar
J415
Actually, that's what I was gonna recommend. Some dry lube. Saturate all your hinges and your latches and get back to us. If it doesn't work, well then your only out 4 bucks.
Old Dec 14, 2010 | 11:47 AM
offroadjosh's Avatar
offroadjosh
I dont have that problem at all when its that cold.. Only problem i ever have is the truck rattles and shakes badly..
Old Dec 14, 2010 | 12:04 PM
I rattle and shake badly when it is that cold out......
Old Dec 14, 2010 | 12:11 PM
Eberron's Avatar
Eberron
Ok I'll give that a try if I can figure out how to get the old sticky junk cleaned out of it. Then I will wait for a nice cold day to test it.
I know what you mean Josh, my old Nissan used to suffer from the old "square tire syndrome" until I drove a few blocks to warm the tires enough to get rid of that flat spot. I haven't really noticed it on the Dodge though...
Old Dec 14, 2010 | 12:37 PM
lvolson's Avatar
lvolson
If you have access to an air compressor, that should help get the old stuff out.
I think they sell the graphite lube as a dry spray.
On a related note (I don't see the need for a new thread.), does anyone have any suggestions to keep the doors from freezing closed?
Old Dec 14, 2010 | 12:43 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Park in a closed garage!
Old Dec 14, 2010 | 02:04 PM
crazzywolfie's Avatar
crazzywolfie
i adjusted my doors and make sure the closed perfectly. i guess if your are worried you could put anti seize on them.
Old Dec 14, 2010 | 03:03 PM
matty675's Avatar
matty675
GOOD GOD! where do you live that it gets 40 below???
Old Dec 14, 2010 | 03:06 PM
Eberron's Avatar
Eberron
Northern BC.
As for doors freezing shut, it's usually caused by water freezing the weatherstripping on the door to the truck. Maybe a thin coat of some kind of lubricant that the ice would not stick to as well? I have been meaning to try something for that myself actually.
