4x4 Problems
Old Dec 14, 2010 | 12:34 PM
qpavel's Avatar
qpavel
Default 4x4 Problems
Hello,
I drive a '94 Dodge Ram 1500. Has the bulletproof 318 in it. Went to drop my truck into 4 wheel yesterday (after a 7inch dump of snow) and it wouldnt engage. I believe it is engaging at the transfer case itself, but not the hubs.
I've heard it could be the vacuum acuator or some vacuum lines. Anyone know much about this or had the problem themselves? All advice is welcomed.
Thanks,
Qpavel
Old Dec 14, 2010 | 12:54 PM
Check some of the other 4x4 threads. My fingers are cold.
Old Dec 14, 2010 | 02:53 PM
qpavel's Avatar
qpavel
I suspect vacuum leak, any tips on where to look though? Transfer case? Hub?
Old Dec 14, 2010 | 03:14 PM
CAD unit on the front axle. Passenger side, back. The lines end there. Follow them back to the t-case. The steel lines tend to rust... also check the supply line from the passenger side rear of the engine, to the t-case switch.
Old Dec 14, 2010 | 11:40 PM
qpavel's Avatar
qpavel
Will do, I'll check it out some and see where I'm at. Appreciate the help.
Old Dec 15, 2010 | 12:13 AM
nmanchester's Avatar
nmanchester
they make a mechanical one that you can replace the vacuum one with it, it only fails if you forget to engage it.
Old Dec 15, 2010 | 12:25 AM
98lifted360's Avatar
98lifted360
I am really need to know about the swap to a mechanical 4wd rather than the one the uses the vacuum lines and all that BS. Parts list web sites and anything would be greatly appreciated!
Old Dec 15, 2010 | 05:55 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Google Posi-Lok
Old Dec 15, 2010 | 07:13 AM
dhvaughan's Avatar
dhvaughan
for vac cad help, read this
http://dodgeram.org/tech/repair/4X4/4x4_engagment.htm
Old Dec 15, 2010 | 11:06 PM
nmanchester
http://www.summitracing.com/search/y...?Ns=Rank%7cAsc
Heres the link for you they have it at summit racing.
