transfer case whine
Old Dec 16, 2010 | 04:39 PM
Does it come from the t-case, or the cv joint right at the t-case?
Old Dec 16, 2010 | 04:40 PM
matty675's Avatar
matty675
i honestly havent tried to distinguish b/w the two, however; wuld the chain move if i spun the front drive shaft by hand while the truck was off in 2wd?
Old Dec 16, 2010 | 05:05 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Remove the front shaft, put it in 4wd and see if you have the same symptoms.
Old Dec 16, 2010 | 06:02 PM
matty675's Avatar
matty675
ok will do, whats it like replacing that double cardan joint?
Old Dec 16, 2010 | 07:52 PM
Tedious, but, not that difficult. If you have replaced a u-joint in the past, you have a good idea of what its all about.
Old Dec 16, 2010 | 08:26 PM
matty675's Avatar
matty675
o yea, i can do a u-joint; but how bout the cardan joint itself?
Old Dec 16, 2010 | 08:43 PM
matty675's Avatar
matty675
this is the part, right?
Old Dec 17, 2010 | 01:52 PM
matty675's Avatar
matty675
it is the chain making the noise. if the chain doesnt move in 2wd, nothing is really compromised by continuing to drive it like that, right?
Old Dec 17, 2010 | 02:12 PM
Correct.
Old Dec 17, 2010 | 02:19 PM
matty675's Avatar
matty675
i found a video on youtube here . this is the exact same noise if your interested
can the chain be replaced with the case still in the truck, what all is involved?
