5.2 that doesnt warm up
Old Dec 18, 2010 | 03:40 PM
meanwhitemopar's Avatar
meanwhitemopar
They are both broke off flush, well this simple projject just got really feeakin tough
Old Dec 18, 2010 | 04:17 PM
aim4squirrels's Avatar
aim4squirrels
Use heat first (mind your gas lines) and then let them cool for a few minutes and douse them with mopar rust penetrant. That stuff is a miracle in a can.
Try a reverse threaded drill bit first. You might get lucky and it back out on that alone, if not then you have a hole to start the easy out.
I once had a header bolt that I broke off in the head (that I had locktited in mind you) and after some heat an the mopar rust penetrant, it was about finger tight.
Old Dec 18, 2010 | 04:19 PM
aim4squirrels
Try a reverse threaded drill bit first. You might oget lucky and it back out on that alone, if not then you have a hole to start the easy out.
Old Dec 18, 2010 | 04:44 PM
meanwhitemopar
I am guessing u get that stuff from the.dealership... wouldn't Pb do the same thing... I think what it is.. aluminum intake, and steel bolt... electrolosis.. welfare it to eachother.. they are broke even so ill try all the ideas... I need my truck back for my upcoming trip back to ny...
Old Dec 18, 2010 | 04:53 PM
Gerehead8's Avatar
Gerehead8
Do you have an welder? You can clean the bolt off really well, weld a washer to the bolt then weld a nut to the washer. I use this trick all the time and it works pretty well.
Old Dec 18, 2010 | 06:06 PM
UnregisteredUser's Avatar
UnregisteredUser
I'm fond of CRC Freeze Off. It's essentially Knock'er Loose with a refrigerant added for the thermal shock. Knock'er Loose was better than PB Blaster before the refrigerant was added, and now as Freeze Off it's better still. Heat up the part, hose it down with Freeze Off, and if it won't move then it's time for drastic measures.
Old Dec 21, 2010 | 06:04 PM
meanwhitemopar
Well, tried heat, Pb blaster and an ex out.. broke the easy out off in it.. I can't even drill the whole bolt out now..
Old Dec 21, 2010 | 06:06 PM
meanwhitemopar
What would be really grwat is if anyone had an old one they would sell me...
Old Dec 21, 2010 | 07:50 PM
Check the junkyards in your area. anything 97 or newer should work. That's where I got mine from.
Old Dec 21, 2010 | 08:56 PM
pcfixerpro's Avatar
pcfixerpro
Haha oh damn. Thats the only thing that scares me about easy outs. Grab a new bit that will drill through the easy out.
