towed a 3500 ford four door dually 4x4 this morning
Old Dec 17, 2010 | 02:53 AM
Joey Buentello's Avatar
Joey Buentello
Default towed a 3500 ford four door dually 4x4 this morning
Got an i'm stranded in the back roads call at 5 am. Did the damn deal and pulled the truck to my buddies girls house about a 35-40 mile tow. The trans got up to about 230 not good, but the motor stayed at about 200 never struggled. But under hard acceleration i get the wacky vents. When I turn the overdrive off and drive I can drive hard and the vents wont change. Whats up with that?
Old Dec 17, 2010 | 03:19 AM
UnregisteredUser's Avatar
UnregisteredUser
What's up with that is that when you're in overdrive the engine is struggling to make power at those low RPM's and your manifold vacuum is on the floor because of the wide throttle opening. So don't do that.
When the engine's working hard, switch into direct drive.
Old Dec 17, 2010 | 08:28 AM
95RAM360's Avatar
95RAM360
never use overdrive when towing...it will cause problems down the road....
Old Dec 17, 2010 | 11:24 AM
Joey Buentello
I was told to use overdrive only on the highway/ freeway. thanks for the info
Old Dec 17, 2010 | 11:40 AM
If you are towing/hauling, O/D will kill your trans in relatively short order. Doesn't matter what kind of road you are on.
Old Dec 17, 2010 | 12:51 PM
TheBigRedOne's Avatar
TheBigRedOne
Congrats, you just bought a new transmission.
Old Dec 17, 2010 | 01:00 PM
justfrfun's Avatar
justfrfun
towed a semi with 53 foot trailer 72,000 lbs to a fuel stop from off ramp of HWY About a mile with 74 cj5 Can/am 304v8 in 4x4 low range. Nobody would help the guy and I made $100 for my new clutch!! But did it with pride!!!
Old Dec 18, 2010 | 07:34 PM
joshmopar's Avatar
joshmopar
Oh and if you tow a lot with a 1500 and tow over bout 7k you will tweek the frame. Ask me how i know. hmmm maby thats why i bought a cummins 3500. oh and i always leave it in direct when towing. trans's are expensive.
Old Dec 18, 2010 | 08:38 PM
Joey Buentello
1700 is what i paid for this trans in 05 and used to tow trash trailors and air compressors for my aunts oilfield equipment rental company with it. Pulls great, just really pissed about the wacky vents. My overdrive doesn't kick in till about 70 ish after that the ac works great. all new check valves btw.
