5.2L engine swap - regulated fuel rail?
Old Dec 24, 2010 | 11:54 AM
fin reaper's Avatar
fin reaper
Default 5.2L engine swap - regulated fuel rail?
Hi all,
I'm swapping a '96 5.2L into my Jeep YJ. I don't have the engine yet but need some help. My Jeep fuel pump is unregulated and uses a fuel return line to the tank. I will be using a '95 ECM and harness to maintain the obd-I.
Does the 96 have a regulated fuel rail with a fuel return? If it doesn't, would a '95 or earlier fuel rail work?
Thanks
Old Dec 24, 2010 | 09:33 PM
rond97sport's Avatar
rond97sport
the regulator is a part of the in tank fuel filter there is no return line .
Old Dec 24, 2010 | 11:23 PM
fin reaper's Avatar
fin reaper
Do any earlier years of the 5.2 have a regulator on the fuel rail?
Old Dec 25, 2010 | 12:46 AM
Plastic or metal? You could always install a fitting for a return line.
Old Dec 25, 2010 | 01:19 AM
fin reaper's Avatar
fin reaper
My wrangler already has the return line. I'm curious if there are any Ram 5.2 years that may have the regulator on the fuel rail, so I can use my return line.
My plastic fuel tank doesn't accomodate the in-tank regulators (yet - sawsall is still in the case).
Old Dec 25, 2010 | 11:01 AM
Another option would be an inline fuel filter with a provision for a return line...... You can plumb the regulator in wherever you really want to...... Don't know if there are stock parts for what you have in mind.
Old Dec 25, 2010 | 11:16 AM
99dodge318's Avatar
99dodge318
so why a 5.2l magnum? there are so many other power plants that have a bigger after market, which equals cheaper parts!
thats unless you trying to keep your jeep all mopar, and in that case go for it!
Old Dec 25, 2010 | 11:30 AM
fin reaper's Avatar
fin reaper
Originally Posted by 99dodge318
so why a 5.2l magnum? thats unless you trying to keep your jeep all mopar, and in that case go for it!
Yep, keeping it in the family. I just found that a Jeep Grand Cherokee 5.2 has a regulated fuel rail.
