318 to a 360 computer swap
Old Dec 22, 2019 | 09:48 AM
grumpygoat's Avatar
grumpygoat
Default perfomance 318
Originally Posted by BiggyT91
I have a 318 pcm on my 360 and it runs just fine I checked all the numbers and they were the exact same
i have a 1994 318 5.2 with some modifications, its bored .20 over, mild cam, aluminum heads with 2.02 valves, 1.6 roller rockers, cold air intake and shorty headers... will a 360 pcu work well and let the perfomance come out?
Old Dec 22, 2019 | 10:01 AM
I think a mopar performance PCM would be better, but, those are getting extremely hard to find.
Unfortunately, there just aren't many folks doing custom tuning for OBDI engines any more. (at least, not for dodge....) May need to upgrade to an OBDII system, (96 or 97) in order to get the most from you engine.
Old Dec 22, 2019 | 10:09 AM
grumpygoat's Avatar
grumpygoat
what all is involved in switching over to an OBD2? do i have to change all the harness and connectors? or is there a way to do it simply?
Old Dec 22, 2019 | 10:14 AM
Simply? Probably not. Need the PCM and harness from a 96 or 97 truck, with same number of cylinders. Manual trans would be best. (you can run some vacuum/pressure switches to control O/D, and TCC) You would have to re-pin some wires into the newer harness though. (anything that runs into the cab. It would be an exercise, but, it's doable.
Other option would be to find a standalone system, that will piggyback on your PCM. Those are easier, but, more money.
Old Dec 22, 2019 | 10:19 AM
grumpygoat's Avatar
grumpygoat
any input on the stand alones that piggyback? brands, or where to search?
Old Dec 22, 2019 | 10:37 AM
I haven't really been keeping up on those.... Several folks make 'em, Holley, etc. Maybe call Summit Racing, and see if they can help.
