Help with tires please!
Old Dec 27, 2010 | 12:58 PM
tatitup8's Avatar
tatitup8
Default Help with tires please!
I got a
99 dodge ram 1500 2wd 5.2l 318 and im looking for tires..
what is the biggest i can do with 22" rims? i need some asap
and i know a guy that has 325/60/22 and i dont know if they will fit?
I HAVE 1.25" SPACERS
Old Dec 27, 2010 | 01:10 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
not a chance buddy, that is a 37.4" x 12.8 x 22
Old Dec 27, 2010 | 01:24 PM
TheBigRedOne's Avatar
TheBigRedOne
I couldn't even clear 37's on my race truck. Without a lift on a 2WD the largest you're going to be able to run is a 32x11 with rubbing. Lots and lots of rubbing.
Old Dec 27, 2010 | 01:27 PM
xxxcowxboyxxx
your race truck is gay...its a ford...and your on a dodge forum.....and just bc YOU cant clear them on your toy racer doesnt mean he cant on his if he lifts it up more than yours
Old Dec 27, 2010 | 01:28 PM
PurplDodge's Avatar
PurplDodge
How many '' low are you?
PurplDodge's Avatar
PurplDodge
Originally Posted by xxxcowxboyxxx
your race truck is gay...its a ford...and your on a dodge forum.....and just bc YOU cant clear them on your toy racer doesnt mean he doesnt have a bigger 2wd lift than you.
Nice constructive criticism. Yeeehaaawwww Cowboy!
Old Dec 27, 2010 | 01:30 PM
TheBigRedOne
You know, that thought crossed my mind as well.
Old Dec 27, 2010 | 01:33 PM
PurplDodge's Avatar
PurplDodge
Well I'm either thinking donk or the guy is laying door with bags. (Bags on a Ram would look pretty damn sweet).
Old Dec 27, 2010 | 01:37 PM
TheBigRedOne
Either that or he wants a ginormous wheels with even more ginormous tires.
Old Dec 27, 2010 | 02:28 PM
dirtydog's Avatar
dirtydog
Moderate User
Seriously.. OP's first post turns out like this? You think you can make a post without namecalling or hostility? Please refrain from useless posts or comments that don't contribute to the question asked. On topic small talk is fine, just keep it amicable.
The OP asked a simple question:
1) What is the biggest tire that will fit my truck(99 1500 2wd).
He doesn't need a smarty pants to tell him which size doesn't fit..That doesn't really help him. If you know that a 325/60/22 doesn't fit then certainly you must know what size does??? He didn't ask what tires will fit and cause tons of rubbing either. I'm more than certain the OP wants to know what is the biggest tire he can fit into his stock vehicle without any rubbing or issue's. I'd guess that a 31.5 x 10.5 with the correct backspacing will be the biggest??? not sure though.
265/45/22 is a 31.4" tall x 10.4" wide
So (245/45/22 + 255/45/22 are on the tall/skinny side) (265/40/22 + 275/40/22 are on the wider under 31" tall) 31" tall means you visibly see 31-22" = 9" of sidewall. 4.5" of rubber on outside of the rim.
tat, do you even know the backspacing or offset to the wheels? That would make a difference as to how wide of a tire you could comfortably fit.
Maybe some more experienced 2nd gen guys can use the above sizes to help you along your way..
