1999 Dodge 2500
Old Dec 28, 2010 | 11:10 PM
AJ287's Avatar
AJ287
Default 1999 Dodge 2500
Hello everybody. Less than 1000 miles ago and new plugs, wires, cap, and rotor, my truck is running horribly. I went to Autozone to get a free diagnostic and I am still having a mis fire on cylinder number 8. I bought a new spark plug and changed it. The old one, that I just replaced 3 weeks ago, is soaked and caked with so much oil, there is no open space. I ran my truck for about 10 minutes and about 4-5 miles and it isn't running any better.
Is my engine shot?????
Old Dec 29, 2010 | 01:14 AM
jasonw's Avatar
jasonw
Site Moderator
Will move this to the 2nd gen section (1994-2001 Dodge Rams), get you some help.
Old Dec 29, 2010 | 01:30 AM
99dodge318's Avatar
99dodge318
you need to go to the search option at the top of the page and do a search on plenum gasket, clogged cat, and o2 sensors.
this is a very common problem with the magnum line of engines. and no your engine is not shot, it just needs some tlc and $$$
Old Dec 29, 2010 | 12:08 PM
AJ287's Avatar
AJ287
Thank you for this info. I will get on it!
Old Dec 29, 2010 | 01:57 PM
lifted99ram's Avatar
lifted99ram
Default misfire?
i have 99 with a 360 and have a misfire on the number five cylinder. i changed the plugs, wires, injectors, cap, and rotor. i still have the miss it comes and goes. i was told by a shop that it is my heads. the 98 and early 99 5.2s and 5.9s have weak valve seats. let me know what you figure out with your truck.
Old Dec 30, 2010 | 08:17 AM
AJ287's Avatar
AJ287
I hope to find out whats happening by this time next week. I will let you know once that happens. I have talked to some people about my truck and I need to get a compression test on that cylinder. With all the ideas that everybody here has given me, I am sure to get this fixed soon!
Old Dec 30, 2010 | 08:28 AM
zman17's Avatar
zman17
Retired Moderator - RIP
As 99dodge318 said, do a search here for plenum. That is the problem.
Old Dec 30, 2010 | 09:07 AM
Rockyhigh360's Avatar
Rockyhigh360
Rent a Compression Gauge from Autozone. It's a simple process that takes one guy and a sheet of paper and a pen. What does your spark plug look like from the missing cylinder?
Old Dec 30, 2010 | 09:36 AM
zman17's Avatar
zman17
See the OP's first post, plenum....
Old Dec 31, 2010 | 08:25 AM
AJ287's Avatar
AJ287
NASTY!!!!!!! It is covered with all kinds of oil and gook!!!! I am amazed that it even ran. The wierd thing about it, is it looked worse than the original one that I pulled out.
