dual exhaust anyone?
Old Jun 14, 2005 | 11:13 PM
krikitz's Avatar
krikitz
Default dual exhaust anyone?
heres the deal. i have a 94 1500 v6 and ive been looking for a dual exhaust system to fit my truck until my eyes bled. the closest i got was some company called pacesetter. the only problem is they only make em for a short bed or a 6 footer...of course mine is an 8 footer. im convinced im gonna have to get it custom made but if anybody has any suggestions id apreciate it
if a system does exist id like to get the side exits but at this point id be just as happy with the rear exits
thanks alot
Old Jun 15, 2005 | 11:34 AM
greenmachine's Avatar
greenmachine
Default RE: dual exhaust anyone?
You could buy the system and put in an extension. I believe you are better off just having a custom exhaust shop put one on for you. They are normally fairy inexpensive
Old Jun 15, 2005 | 11:37 AM
jimmyperry_00's Avatar
jimmyperry_00
I agree that it would be best to get a custom exhaust done. That way you could get it done however you want it. It would be no more expensive than ordering one.
Old Jun 15, 2005 | 12:44 PM
krikitz's Avatar
krikitz
ok guys thanks alot ill probably do that then after my intake comes in and we get that put on
i posted some questions i have about lifts too if yall have any input id apreciate that alot too
Old Jun 15, 2005 | 01:29 PM
steve05ram360's Avatar
steve05ram360
check these guys out, they have true dual setups, maybe they have one for your setup...
http://www.gsmotorsports.com/
Old Jun 15, 2005 | 03:35 PM
krikitz's Avatar
krikitz
yea my problem is finding one for the small engine, its only a 6 banger
all those on that page are for bigger engines and later year models
Old Jun 15, 2005 | 03:55 PM
steve05ram360
I've seen the flanges and 90 deg bends at Summit, you maybe able to do your own...
Old Jun 15, 2005 | 04:34 PM
krikitz's Avatar
krikitz
wow they actually have a dynomax system and a flowtech system that fits my truck
well done sir
you have any preference on these? the goods
Old Jun 15, 2005 | 04:42 PM
steve05ram360
you might consider doing this... check into the performance gains 1st though... get this p/n SUM-642125, then get the collectors from summit (not sure on the p/n) and see if you can find a 45 deg (I'm guessing here) piece to tie the two together... On my truck, the header collectors are at a 45 deg angle to the ground, so it makes it a little challenging for me to put my own kit together for my truck. otherwise a y-pipe for a late model 4x4 would be excellent!!! (no-one makes one).
does your exhaust manifold have the collector by the firewall? or is it in the middle of the manifold? I havent seen one so I'm not sure what the setup is.
edit: actually, now that I think about it, true duals would not be a good idea on your truck since your motor is so small... you'll need as much low end torque as you can get, I'd do a cat back setup from Flowmaster either 3" single out or go with dual 2.5" out reduced down to 2.25"...
Old Jun 15, 2005 | 05:10 PM
krikitz's Avatar
krikitz
right i want to keep the torque but i want to duals too so i was plannin on goin with a smaller tubing
2 1/4 on a cat back should be alright though?
