What is this? intake air temp sensor
Old Jan 2, 2011 | 09:33 PM
Its a scam. Someone paid a bunch of money for a resistor in a box, that 'fools' the PCM into thinking the intake air charge is cooler than it really is, thus, richening up the mixture in OPEN loop mode.
Get rid of it. Doesn't do a damn thing for your engine.
Old Jan 2, 2011 | 09:34 PM
Buellstunter's Avatar
Buellstunter
Default What is this? intake air temp sensor
Does anyone know what this little black box would be attached to what I believe is the intake air temp sensor?
Old Jan 2, 2011 | 09:44 PM
Buellstunter
Thanks! I assume i just eliminate the box and hook the wires to the same colors that they are hooked to now?Maybe that will help the miss it has when its cold. Just bought the truck. trying to work out the bugs. thanks again.
Old Jan 2, 2011 | 10:20 PM
Don't know if it will do anything about the miss..... Are you getting any codes?
Old Jan 3, 2011 | 05:27 AM
Buellstunter
When i brought it home on Wed. evening I scanned the computer and it had multiple codes. Didnt write them down just reset the computer to see if they would come back. So far they didnt. I do remember it had a generic misfire code. then had individual misfire codes for cylinders 1-8. the individual cylinder one said "intermitent misfire" .Also had a trans temp code.
Old Jan 3, 2011 | 09:41 AM
dipsherry's Avatar
dipsherry
well that little black box will make u waste fuel so take it off
Old Jan 3, 2011 | 10:37 AM
Change the spark plugs. Check your cap, rotor/ and wires. I had random misfire codes for all eight..... my distributor cap was rather carboned up..... just changing the plugs made a big difference.
Old Jan 3, 2011 | 04:00 PM
Buellstunter
Ok, Ill check the cap and rotor. the genius that i purchased the truck from said he changed the plug wires, but didnt change the cap rotor or plugs for some reason.. lol. I changed the plugs the next day after i got it. it had autolite Xtreme performance plugs in it that reminded me of an
iridium plug with the tiny electrode. they didnt look bad at all. But i replaced them with a standard autolite plug gapped at what the manual reccomended. i have cap and rotor to put in, but was tryin one thing at a time to pinpoint the miss/hesitation it has when its cold. it was about 30deg. this morning and between 1dle and 1/4 throttle it would pop and miss till it got warm then run great. has me puzzled to say the least.
Old Jan 3, 2011 | 04:21 PM
Mine pulled that trick for a few feet yesterday.... it was kinda chilly, but, it only did it for a very little bit, when I was first pulling out of the driveway. All of my ignition parts are new...... hasn't done it again yet. might just have been a fluke, or, I may be looking at digging for this one too.....
Old Jan 3, 2011 | 05:11 PM
Silver_Dodge's Avatar
Silver_Dodge
Clean your TB and IAC. I've had mine do this if I get a lot of fouling on the tip of the IAC sensor or in the idle air passage. It will backfire out the TB and run rough till it warms up.
