missing and chugging ?
Old Jan 3, 2011 | 04:33 PM
redtwin's Avatar
redtwin
Default missing and chugging ?
I have a 98 dodge ram 1500 w/318 it runs and drives perfect,shifts good,but it has a miss or chugging feel at cruising speeds like holding a steady speed between 45 to55 or higher,any ideas would be helpful,have run 2 tanks of gas with injector cleaner with no change
Old Jan 4, 2011 | 12:48 PM
redtwin's Avatar
redtwin
bumpp
Old Jan 4, 2011 | 02:00 PM
Sounds like you have a miss. (mine felt the same way....)
Start with a tune-up. Plugs, wires, cap, rotor. Might solve the issue. (get GOOD quality wires...... spend a little more, have fewer problems....)
Have you checked your plenum gasket??
Old Jan 4, 2011 | 02:17 PM
lukeca's Avatar
lukeca
My old 96 with the 5.9 did that, new plugs cured it for me (the wires were fairly new also, but replaced at an earlier time)
Old Jan 4, 2011 | 02:59 PM
redtwin's Avatar
redtwin
JUst bought the truck a few months back tune up was done just done think ill pull the plugs and see what they look like,what are the signs that the plenum gasket is bad?
Old Jan 4, 2011 | 03:06 PM
The rear plugs, especially number 8, will be oil fouled.
You can also look down the throttle body, if you see pooled oil...... time to fix it.
Old Jan 4, 2011 | 06:26 PM
grox's Avatar
grox
What's the deal with this forum and plug wires? What's wrong with standard wires?
Old Jan 4, 2011 | 06:58 PM
A rather critical part of your ignition system. The stock ones were crap when new. A fair number of the over-the-counter replacements are crap as well. Even dodge knew this, that's why there is a tech service bulletin regarding plug wire routing, as even NEW from the factory, they had problems....... (plug wire cross talk)
Old Jan 4, 2011 | 07:17 PM
grox's Avatar
grox
So it's an insulation issue? I just don't see the need for the fancy 8.5mm wires, unless you're running an upgraded coil
Old Jan 4, 2011 | 07:55 PM
UnregisteredUser's Avatar
UnregisteredUser
Not insulation, but inductive coupling.
