Transmission line help
Old Jan 3, 2011 | 07:30 PM
whiskerbiscuit's Avatar
whiskerbiscuit
Default Transmission line help
Hello everyone; I will have to replace my radiator and was wondering what was the best was to remove the bottom trans line to the radiator. It's in a 97'' with a 5.9. Do i need any special tool to remove it? Thank's guy's..................Mike
Old Jan 3, 2011 | 08:00 PM
Yep. Need the special quick disconnect tool. Any auto parts store should have 'em. You want the 3/8ths flavor. Do NOT get he X style one, that does a bunch of different sizes, it won't fit in the space available to release the fitting. (ask me how I know......)
Old Jan 3, 2011 | 09:27 PM
dhvaughan's Avatar
dhvaughan
aka "fuel line disconnect tool".
here's an expensive set.
http://www.harborfreight.com/4-piece...set-96834.html
here's the cheap one, which is fine.
http://www.harborfreight.com/6-piece...ool-97576.html
Old Jan 3, 2011 | 09:40 PM
cmckenna's Avatar
cmckenna
Since I've got to replace a hose myself (due to weeping fitting), what is the part number for the hose that contains that check ball? I need to order one up and R & R before the old one totally lets go.
Thanks,
CM
Old Jan 4, 2011 | 02:01 AM
whiskerbiscuit
Guy's THANK YOU! The X style one just aged me ten years. Piece of s**t. Going in the morning to get the four piece set...............................Mike
