Dana 44 gear size
Old Jan 4, 2011 | 11:18 PM
smcandrew08's Avatar
smcandrew08
Default Dana 44 gear size
I have a dana 44 and i cant remember if i have 3.73 or 3.92 gears in the front. I was ordering new 4.56 gears to match the back (put in by po so i dont know what the rears were). Is there an easy way to tell what gears were stock to the truck like on the vin or somewhere else so that i dont have to do actually do any physical work to check what i have again? My problem when ordering the gears is that if i have 3.73s the carrier is different then 3.92s so i need to get it right the first time i order.
Old Jan 4, 2011 | 11:21 PM
Go to the dealer, give them your vin, they will be able to print you off a build sheet that will tell you what gears you have.
Old Jan 4, 2011 | 11:23 PM
smcandrew08
sweet thats the kind of answer i was hoping for. Thanks
Old Jan 4, 2011 | 11:25 PM
merc225hp's Avatar
merc225hp
You can check your old threads, If I remenber right you posted that you had 3.92 in the front.
Old Jan 4, 2011 | 11:34 PM
merc225hp's Avatar
merc225hp
Here you go
Quote:Ok so i checked out the front and rear gears. It turns out i have 3:92 in the front and 4:56 in the rear. So now my question is do i only need to repace the front ring and pinion to a 4:56 or is there other parts that i have to swap as well. It does have the dana 44 and i am getting the thick r/p so that i dont have to get a new carrier. Is this a job you can do your self or does it require special tools?
https://dodgeforum.com/forum/2nd-gen...f-gears-2.html
Old Jan 4, 2011 | 11:40 PM
smcandrew08
Hahaha i totally forgot i even posted that thanks. So does everyone agree that i want to get the 4.56 gears that are 3.73 and up carrier?
Old Jan 4, 2011 | 11:42 PM
If that's the way they break on the dana 44, those are the ones ya want. I would verify that though.... I thought the break was 4.10, and up? I might be hallucinating though.....
Old Jan 4, 2011 | 11:48 PM
smcandrew08
haha i will double check its coming from randys ring and pinion so i will deff make sure i ask to make sure.
Old Jan 4, 2011 | 11:54 PM
merc225hp's Avatar
merc225hp
Dana 44 Carrier Breaks: 3.73-lower, 3.92-higher
Old Jan 5, 2011 | 09:02 PM
smcandrew08
Does anyone know if i should use a reverse cut or a standard rotation ring? I have researched it a bit but i dont know if the dana already came with a reverse or is it a standard rotation ring and pinion that comes stock with the dana 44s?
