trans shifting weird under throttle out of first
Old Jan 6, 2011 | 02:39 AM
deeznutsmaketea's Avatar
deeznutsmaketea
Default trans shifting weird under throttle out of first
my truck started doing this weird thing where if you romp it to the floor it won't shift out of first gear unless you let off....any ideas?
the truck is a 95 ram 1500 sport 5.9 360 i got it with 83xxx miles and so far i have 114xxx on the clock. nothing major done to the truck except new water pump and new muffler to replace the flowmaster that got deer antler shoved into it. at 80mph =)
Old Jan 6, 2011 | 04:22 AM
UnregisteredUser's Avatar
UnregisteredUser
Try adjusting the throttle valve cable. Can't hurt, it's free, might help.
Old Jan 6, 2011 | 09:21 AM
Adobedude's Avatar
Adobedude
Yup....one notch at a time....PIA
If that doesn't work you could solder in a 1/2 watt 100 ohm resistor into the wire coming from Pin 31 of the center connector from the PCM, This usually done with a performance valve body, some guys have done it stock VBs though.
Maybe start with a 50 ohm, if that doesn't work, add another 50, just make sure it's 1/2 watt, not 1/4.
Old Jan 6, 2011 | 11:08 AM
What does that do?
Another consideration would be.... the pressure transducers (sensors) for the governor on the 46RE trans is notorious for not reading correctly at sustained high load values. (high pressure, such as, when you are sticking your toenails into the radiator.)
Old Jan 6, 2011 | 11:11 AM
zman17's Avatar
zman17
Retired Moderator - RIP
What does that do?
Problem there is, it's a 95.
Old Jan 6, 2011 | 11:13 AM
LOLOLOL.
Good point. I REALLY need to pay more attention to such things.
More coffee. Mooorrreeee Cooooffeeeeeee.........
Old Jan 6, 2011 | 11:24 AM
Adobedude's Avatar
Adobedude
LOLOLOL.
DOH...I missed that part too....LOL
Nevermind.
Old Jan 6, 2011 | 11:27 AM
zman17's Avatar
zman17
For both of ya, LOL
Old Jan 6, 2011 | 03:24 PM
UnregisteredUser
I'm so glad it wasn't me neglecting to observe the details this time!
Old Jan 6, 2011 | 06:18 PM
Adobedude's Avatar
Adobedude
What does that do?
Since you asked....With a 46RE, the PCM looses it with added governor pressure from a shift kit, and/or increased line pressure and it doesn't shift on the 1-2 at WOT.
The resister fools the PCM into thinking everything is normal. Most guys whom sell modded valve bodys install the reisitor in the Wiring harness in the valve body so they know they have the right wire. Like I said, you can go with a 100 watt, or a couple 50s in parallel, or go with a 100 watt and a 25...Whatever it takes.
