Whats the biggest tire i can get on stock rims
Old Jan 13, 2011 | 01:28 AM
Rpare92's Avatar
Rpare92
Default Whats the biggest tire i can get on stock rims
Hey guys im lifting my 99 sport its a 2wd (gasp!) im doing the 6.5 inch fabtech lift and was wodering what size tire i could get on my stock rims. They are 16 inch could i run 315/75/16?
Old Jan 13, 2011 | 08:45 AM
slider15004x4's Avatar
slider15004x4
Those would be pushing it on a 7" wide rim. 285's are the biggest I have seen installed in stock rims.
Old Jan 13, 2011 | 08:50 AM
Ugly1's Avatar
Ugly1
There is a difference between what fits on there and what you can get balanced well. 12.5" wide tire is too big for stock IMO. I'd go with like a 9" rim with those tires if you can.
Old Jan 13, 2011 | 09:01 AM
drewactual's Avatar
drewactual
I keep hearing that you never want to have a tire greater than 3" wider than the rim.. Makes sense to me..
I mountain bike, and the two families of tire considerations are related- the closer the two are in widths, the 'squarer' the profile.. If the rim is significantly narrower, the tire will 'balloon', and be really susceptible to rolling off the rim.. that is a very bad thing.. the squarer, the more bite the edge has into the terra in turns, and the more flat the tread sits on asphalt- for longer tread life..
a 'ballooning' tire will also put a LOT of stress on the bead, and they will roll horizontally in turns making the truck seem to wallow.. If you ever take it off road and lower the pressure, you're amplifying these effects..
Old Jan 13, 2011 | 03:38 PM
Rpare92's Avatar
Rpare92
I found this truck on cardomain its also a 2wd it has 37-12.5s on stock rims whats the difference between 315/75/16
[IMG]file:///C:/Users/paige/AppData/Local/Temp/moz-screenshot.png[/IMG]http://memimage.cardomain.com/ride_images/1/3828/3461/9569230001_large.jpg
http://www.cardomain.com/ride/956923...00-regular-cab
Old Jan 13, 2011 | 03:41 PM
99dodge318's Avatar
99dodge318
a 315 is pretty much a 35" tire
Old Jan 13, 2011 | 03:42 PM
PurplDodge's Avatar
PurplDodge
I'd like to see his rear axle and front wheel bearings after doing that.
Old Jan 13, 2011 | 06:08 PM
drewactual's Avatar
drewactual
315 is the width.. the second designation is height in percentage of width.. double that and add diameter for the tires overall height (advertised height, don't even get me going about discrepancies in real height vs. advertised)
315/70/17 would be just shy of 12 1/4" wide, and with a sidewall around 8.5", which would be 34" tire roughly..
315/60/17 would be 31 1/2" tall..
315/75/17 would be 35 1/3" tall..
those 315/75/16 are 34 1/3" tall.. 12 1/4" wide tires on a 7" rim is over 5" difference.. You can take the chance if you like, but I wouldn't do that unless I was heading in a direct line to the rim store...
that second number is the trick- as you can see there is a pretty good difference in those tires..
Old Jan 13, 2011 | 06:40 PM
xxxcowxboyxxx's Avatar
xxxcowxboyxxx
and that is why i now have dana 60's
