ABS and Brake Light
Old Jan 14, 2011 | 11:38 AM
99ramjrbo's Avatar
99ramjrbo
I had the same problem with my truck. Changed out the sensor and no problems what so ever. Took me about 15 minutes to change it out.
Old Jan 15, 2011 | 03:08 PM
Road Hammer's Avatar
Road Hammer
2001 Ram 1500 2WD, I have 4 wheel ABS and the ABS and Parking brake lights came on recently, but did not remain on after restarting the truck. Last night they came on again and have not gone out. It seems that this system is only giving me trouble when it's very cold outside, both times this happened it was approx -30C. Is it possible that ambient temperature is causing this system to throw a code? Can I just leave it until spring (when it's warmer!) and replace the sensor on top of the rear diff, or can I just "disarm" the ABS system and get rid of the damn lights on the dash! LOL
Old Jan 15, 2011 | 03:37 PM
97r/tram's Avatar
97r/tram
Mine was on a while back, but after putting the 2nd sensor in and the light came back on, I just took the lights out of the dash for the abs and parking brake. Does that speed sensor control the shift points?
Old Jan 15, 2011 | 03:38 PM
usranger80's Avatar
usranger80
it really is only a ten min job to change that sensor at the most, I did it last week after putting it off forever, the part is about 20-30$ at your parts store and once I changed it the lights were gone and my speedometer started working under 25MPH again.
Old Jan 16, 2011 | 11:36 AM
Road Hammer
Well everything else on my truck appears uneffected by the ABS and Parking Brake lights being on, but it sure is driving me nuts! LOL The sensor that you changed in 10 mins, is that the one mounted on the rear differential? Remember, mine is 2wd with 4 wheel ABS. Thanks guys,
Old Jan 16, 2011 | 12:08 PM
You should take it somewhere they can read the abs codes. You have a couple extra sensors there that could cause the same problem.
Old Jan 16, 2011 | 06:35 PM
usranger80's Avatar
usranger80
Mine is also 2wd with 4w/abs and yes that sensor took care of it, one bolt holding it in and a connector and it was done, right on top of the pumpkin on the rear axle.
Old Jan 19, 2011 | 12:46 PM
BamaRam97's Avatar
BamaRam97
Finally got the sensor today from NAPA. Do I need to clear the ABS Code before installing the new ABS Sensor on the rear diff? Or will it clear itself when I install the new one? Does it even matter?
Old Jan 19, 2011 | 12:51 PM
J415's Avatar
J415
Clear the codes whenever you change parts.
zman17's Avatar
zman17
Retired Moderator - RIP
Disconnect the negative battery cable while you replace the sensor.
