ABS and Brake Light
Old Jan 14, 2011 | 08:53 AM
BamaRam97's Avatar
BamaRam97
Default ABS and Brake Light
This morning as I was leaving for work my ABS indicator light came on. Its the first time I have ever seen this warning light. I don't really have any symptoms or anything out of the ordinary. Brake fluid level is good. The pedal feels the same. I didn't slide or lock up on my drive to work although it is only about 15 minutes. I haven't had a chance to get the code read yet and I'm going out of town this weekend in my truck. Should I be extremely worried? I don't want to start a run away Dodge conspiracy like the Toyota Prius, which I also own. Any help would be great!
Thanks
Old Jan 14, 2011 | 09:02 AM
zman17's Avatar
zman17
Retired Moderator - RIP
The sensor on top of the rear end is the most likely culprit.
Old Jan 14, 2011 | 10:33 AM
BamaRam97's Avatar
BamaRam97
So you are thinking this one?
http://www.autozone.com/autozone/par...4_55326_0_4024
I guess I won't have anti-lock brakes until I change the sensor out. How could that sensor possibly change shift points in the tranny? I'll get it checked with a tuner to make sure it is that sensor.
Old Jan 14, 2011 | 10:40 AM
Not like the antilock brakes are worth a hill of beans on these trucks.......
PCM pays attention to a host of sensors when deciding various things..... transmission pressures is one of them. It is possible that the sensor in question could cause you problems of that nature, but, I don't know for sure one way or the other....
Old Jan 14, 2011 | 10:47 AM
zman17's Avatar
zman17
I say just change the damn sensor, 10 minutes if that. You can also try this and see what codes you have https://dodgeforum.com/forum/2nd-gen...code-list.html
And btw, don't use any Duracrap sensors.
Old Jan 14, 2011 | 10:53 AM
BamaRam97's Avatar
BamaRam97
Thanks for the help fellas. I'll get the code checked and grab a new sensor. I'm guessing the NAPA brand sensors are pretty good right?
Old Jan 14, 2011 | 11:02 AM
BamaRam97's Avatar
BamaRam97
Our trucks only have rear wheel ABS right? I remember putting the ABS Ring back on in the rear when I installed new gears and the locker. I don't remember doing that in the front.
Old Jan 14, 2011 | 11:19 AM
The trucks that have 4wal have speed sensors at each front tire, as opposed to on the carrier. It was an option.... but, I haven't seen too many that actually have it. (as a matter of fact.... I have yet to see one.....)
zman17's Avatar
zman17
Just RWAL on a 97. IIRC it was an option later on.
Old Jan 14, 2011 | 11:32 AM
BamaRam97's Avatar
BamaRam97
Thanks again fellas. You have been a big help as usual!
