engine trans swap...will it fit?
Old Jan 14, 2011 | 09:27 AM
gdamtbnms's Avatar
gdamtbnms
Default engine trans swap...will it fit?
this is what i have... 96 ram 1500 4x4 5.9 magnum
this is what i might get...
1998 Dodge Ram 1500 reg cab short bed 2WD
318ci 5.2L V8
46RE automatic with OD
will it fit?
Old Jan 14, 2011 | 10:11 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Motor not a problem, but the tranny's are different between 2wd and 4wd.
Old Jan 14, 2011 | 11:23 AM
gdamtbnms's Avatar
gdamtbnms
I thought my trans was the 46 re....are there different types of 46 RE's?
Old Jan 14, 2011 | 11:31 AM
zman17's Avatar
zman17
Yes, 2wd and 4wd! Can you explain a little bit better about what you are trying to achieve? Like which motor/trans is going where?
Old Jan 14, 2011 | 10:14 PM
crawlin95's Avatar
crawlin95
you can swap the over drive sections and it will work. well at least it did on my 46rh. but i beleive the same is true for the re
Old Jan 14, 2011 | 10:41 PM
jasonw's Avatar
jasonw
Site Moderator
I may be mistaken, but I think the wiring between 1996 and 1998 transmissions will be different. You may have to do a custom wiring job.
Old Jan 14, 2011 | 10:45 PM
matty675's Avatar
matty675
isn't the '98 RE different from the '96-'97 RE?
Old Jan 15, 2011 | 02:55 PM
gdamtbnms's Avatar
gdamtbnms
basically i was just looking for a back up engine and trans for my truck in case it ever died on me. Right now everything works but my trans surges and i'm pretty sure i have problem cylinders but in general all runs well just sounds like it misses everynow and again and i got my check engine light stuck on do to random misfires etc
Old Jan 15, 2011 | 05:35 PM
zman17's Avatar
zman17
In that case, your plenum is blown(do a search here on DF for that), the pre cat o2 sensor is hosed, and your cat is most likely clogged.
Old Jan 16, 2011 | 02:08 PM
gdamtbnms's Avatar
gdamtbnms
I actually already replaced my plenum gasket with the kit you guys recommended lol
its the after the cat sensor...bank 2 and i had replaced it with a new one. So it is possible the cat could be clogged... but it looks as though it may be gutted by a weld i spotted like a trapt door.
i got 2 codes. One spacifically noted cylinder 3 and the other is just random cylinder misfire...i was leaning twards a faulty injectors
