no heat, help
Old Jan 19, 2011 | 01:06 PM
Big Guz's Avatar
Big Guz
Arrow no heat, help
blower motor works, temp changes to cool and back to warm just not warm enough at all. I replaced the thermostat and the engine get up to about 180 degrees according to the gauge. I think the problem is I put a fail safe thermostat in and maybe it's a 180 degree one. Is that warm enough to get good heat from or could there be another problem? I also just did the radiator and water pump not too long ago but the problem was even before that. I can't remember if I blew out the heater core or if that was in my 94 ram, this is a 98.
Old Jan 19, 2011 | 01:17 PM
back flush the heater core. when you put the hoses back on, try and lose as little fluid as possible. Having a helper makes the exercise easier.
Old Jan 19, 2011 | 07:48 PM
Big Guz's Avatar
Big Guz
yeah, I had to do this to my 94 ram. It worked pretty good. Thanks
Old Jan 20, 2011 | 01:00 PM
98Woo2500's Avatar
98Woo2500
if it only was that easy.................
