Huge pisser.. what would you do?
Old Jan 20, 2011 | 04:42 PM
  #41
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by drewactual
It happened when I wasn't around.. I suspect it was from tearing through the mud, and most likely running it hard.. I'm out.
Nuff said. Good luck, I hope you get her fixed.
Old Jan 20, 2011 | 05:16 PM
  #42
UnregisteredUser's Avatar
UnregisteredUser
I pulled the valve covers yesterday..
I've gotta admit that I haven't looked under a Magnum valve cover recently so could be suffering from faulty memory, but aren't the bores in the head through which the pushrods pass large enough to also pass a lifter?
Old Jan 20, 2011 | 05:22 PM
  #43
UnregisteredUser
Originally Posted by PurplDodge
You're letting people screw up your **** and you're not doing a damn thing about it. It doesnt matter if you are 7 or 70, make $7000 or $700000 a year, people should be held accountable for their actions.
Therein lies the rub, young friend. He's got every legal right to sue the pants off of the clowns who rodded his truck, but his employer has every legal right to fire him in order to restore harmony to the work environment. Which is to say that your exercise of your legal rights does not preclude the exercise by others of their legal rights.
It's a wise man who chooses his battles carefully.
Old Jan 20, 2011 | 05:29 PM
  #44
dodgeram07's Avatar
dodgeram07
you have to pull the intake to get to the lifters, i been there twice now
i got mopar lifter for around 100bucks and shipping
you can also take the lifters apart and clean them, there isnt and hole alot to them
lifters in the courter and i alittle bit harder to get out(but that was me) they all hit the head gaskets when they are getting pulled out,,, but they will come out with out doing any thing to the head gaskets
Old Jan 20, 2011 | 06:44 PM
  #45
cmckenna's Avatar
cmckenna
This is correct and, in order to even get them started to come out, it's by accessing them via the lifter valley. There's no way to extract them via a top-down method.
CM
Old Jan 20, 2011 | 06:57 PM
  #46
UnregisteredUser
Thanks for setting me straight, guys.
Old Jan 20, 2011 | 07:17 PM
  #47
chrscott's Avatar
chrscott
Is it worthwhile to try and rebuild lifters?
As I understand it, there is just a check ball, a spring, and some rubber seats in our lifters. The most common failure modes being debris in the oil passage (preventing oil flow), or deposits on the ball bearing (preventing sealing to the seats, and causing bleed down).
Do you need parts to rebuild a lifter (like new seats and ball bearing), or do you just soak everything carb cleaner or something?
When I replaced mine (had one noisy lifter, that wasn't pumping oil), I replaced all of them with new lifters becuase I didn't want to have to pull the intake manifold again.
Anyone just rebuild and reinstall with any success?
Old Jan 20, 2011 | 07:22 PM
  #48
I have never bothered with rebuilding them. Mainly because most of the mechanics I talked to that tried it.... failed miserably..... Replacement is guaranteed to solve lifter problems. That is good enough reason for me.
Old Jan 20, 2011 | 07:52 PM
  #49
charlie1935's Avatar
charlie1935
In the early 1960's I saw a guy disassemble all his lifters and put all the parts in one bucket to clean.
Needless to when he got it back together the hemi clattered like hell!
He probably would have been OK if he had kept each one separated but after his screw up he brought a set of lifters.
Old Jan 20, 2011 | 10:26 PM
  #50
CPTAFW163's Avatar
CPTAFW163
Damn, Drew. This stinks. I am sure that "The Corps" will take care of their own this time, and they can spring for the parts (some/all). Then they know that they will not mess around the next time they do some work.
It will all work out. The Military is like a Fraternity. You flog eachother, but you also get along. Right now you just feel like the guy who passed out first at the party and someone taped a maxi pad over your mouth and put panties over your head.
