Huge pisser.. what would you do?
Old Jan 22, 2011 | 06:17 PM
  #71
drewactual's Avatar
drewactual
If CM says it.. I trust it..
If ANY oil dislodges something in the engine that makes its way near one of those lifters when they are rebounding, they stand a good chance of sucking it up.. the port for charging the lifter is pretty small- about .009~010 in diameter.. if something clogs it, even for a second- I could so see a clack.. I'm guessing when it is being compressed, the same debris would be forced away, which would correct the problem..
If something small enough were to infiltrate that tiny port and get inside the lifter, that would light a fuse on the lifter methinks..
If'n syn oil does the things it's scientifically proven syn oil does, this wouldn't bode well for tiny openings and debris in the oil.. the debris, and the 'cajun crust' being the worst..
I'm going to open them up Unreg.. I'm wondering, now, if those things have that crust on the inside of them.. THAT, would wreck a seal, and a wrecked seal would eff with the intended stroke of those pistons, which would toss a spring out of whack.. I'm curious enough to do it now.
Old Jan 22, 2011 | 06:23 PM
  #72
Post pics.
Old Jan 22, 2011 | 06:30 PM
  #73
lastrights's Avatar
lastrights
i just bought 5 quarts of M1 sythetic high milage . should i get mobil 1 convetional ? or what do you reccomend ?
Old Jan 22, 2011 | 06:38 PM
  #74
Dino Oil.
  #75
lastrights's Avatar
lastrights
what is dino oil lol
Old Jan 22, 2011 | 06:42 PM
  #76
Not synthetic.
Old Jan 22, 2011 | 07:10 PM
  #77
Annihilator_X9's Avatar
Annihilator_X9
Not to thread jack here, but I just switched back to Castrol GTX frpm M1 full syn and man does it make a difference. Much more quiet and smooth.
Old Jan 22, 2011 | 07:38 PM
  #78
UnregisteredUser's Avatar
UnregisteredUser
Originally Posted by Caution
Dont care what oil is used, if you over rev it things break. PERIOD.
These engines won't over-rev unless the PCM is diddled with.
Old Jan 22, 2011 | 07:39 PM
  #79
UnregisteredUser
Originally Posted by drewactual
I'm going to open them up Unreg.. {...} I'm curious enough to do it now.
I've love to see some pictures of the innards undisturbed from their as-removed state!
Old Jan 22, 2011 | 08:14 PM
  #80
Caution's Avatar
Caution
Sure you can. Drop her into 1st. That was easy lol.
