I have a hose hanging on the ground coming from the front axle, what is it?
Old Jan 19, 2011 | 11:33 PM
vikingdiesel's Avatar
vikingdiesel
Default I have a hose hanging on the ground coming from the front axle, what is it?
I just noticed a hose coming from the pass. side front axle just chilling on the ground, it has a white plastic end piece that has a broken off tip, it looks like a vacuum line, but NOT sure, what is it and where does it go to, pics would be nice, TIA
Old Jan 19, 2011 | 11:35 PM
Vent hose. Should be a clip up there somewhere for it. I think mine runs up behind the shock tower, on the inner wheel well. Little dark and cold for pics.
Old Jan 19, 2011 | 11:36 PM
pcfixerpro's Avatar
pcfixerpro
Vent tube, pop your hood and goes on passenger side fender well
Edit, HeyYou is too quick lol
Old Jan 20, 2011 | 12:06 AM
vikingdiesel
do I need the new white plastic clip at the end or nozzle, whatever its called? Does it actually go into something?
Old Jan 20, 2011 | 12:19 AM
pcfixerpro's Avatar
pcfixerpro
the white part doesn't, that is the vent portion. there should be a plastic clip that clamps onto the hose, and should have a door panel push pin style piece on it as well that will go into the fender. (look for a hole)
EDIT
Look towards the PCM, there is a black hose running up and a white vent on top.
Old Jan 20, 2011 | 12:37 AM
vikingdiesel
ohh ok, thats it!!! NICE!!! THANK YOU
Old Jan 20, 2011 | 12:58 AM
vikingdiesel
btw, is there a CAP over that hole is should that hold be open? Kind of a weird setup, thats all
Old Jan 20, 2011 | 07:27 AM
dhvaughan's Avatar
dhvaughan
the little white cap is a check valve that keeps debris out. if yours is lost you should replace it. i wouldn't think it would cost more that a couple of dollars new, or you could get one from a junk yard probably for nothing.
Old Jan 20, 2011 | 03:34 PM
vikingdiesel
I just found a grey plug with 2 wires pulled out of it, what is that? Also sits on the passenger fender
Old Jan 20, 2011 | 03:35 PM
Pic please.
