Fixed my "engine is too cold for too long" problem!
Old Jan 23, 2011 | 03:42 PM
EndIsNear's Avatar
EndIsNear
Default Fixed my "engine is too cold for too long" problem!
Well, I was snooping around the ole' dodge today and figured id try looking at the temperature sensor. Upon observing it, the entire probe had corroded away, and the sensor part just pulled out. The golden looking shell was still screwed in. so I got a new one, installed it, and the temperature went right to normal. Only thing im worried about is the electrical plug is a bit loose... Seems to be okay though
Old Jan 23, 2011 | 06:52 PM
justfrfun's Avatar
justfrfun
Did we change the coolant?
Old Jan 23, 2011 | 07:18 PM
Dodgeman000's Avatar
Dodgeman000
Do yourself a favor and do a coolant flush. It A sign of things to come. Examples, leaking rad, heater core, or worst of all freeze plugs
Old Jan 23, 2011 | 08:17 PM
EndIsNear's Avatar
EndIsNear
Well see, I just did that not too long back while trying to mitigate the problem. Should I do it again?
If you have done it recently, you should be golden.
Old Jan 23, 2011 | 08:49 PM
Mad_Scientist's Avatar
Mad_Scientist
Recently ran into problems with that myself, if you are concerned and would like to know what problems that loose connection can birth, do a search for my thread: So... did my ect just eat itself?. Cant figure out how to post up a link to it or i would
Old Jan 23, 2011 | 10:13 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Electrical connections should always be tight.
Old Jan 23, 2011 | 10:47 PM
EndIsNear's Avatar
EndIsNear
Well, they should. But after heating and cooling the plastic constantly, and the corrosion that ate the probe in half, I can understand why it would be loose... I mean, the temp probe is exacty the same as the old one.
Old Jan 23, 2011 | 11:21 PM
madmax0r's Avatar
madmax0r
yea do the coolant flush for sure, i had a freeze plug blow out 70 miles from the house and had to replace it late sunday night before a work day in a sticker patch. Fml.
