No fast idle engine lite on
Old Jan 26, 2011 | 12:03 PM
gilardis13's Avatar
gilardis13
Thumbs up No fast idle engine lite on
Hi I have a 1995 dodge ram and my first problem is changing my rusted out plugs. I can't even get my socket in to get at the plugs. Can I cut off the shields. Any suggestions????
Next is my check engine lite is on and I have no Fast Idle on cold start. How do I turn the idle up??
Old Jan 26, 2011 | 12:55 PM
1969CoronetR/T's Avatar
1969CoronetR/T
vaffanculo
Welcome to the site. I will move this thread to the second generation Ram section,
FF
Old Jan 26, 2011 | 12:59 PM
Idle is controlled by the PCM via the IAC motor on the back of the throttle body. Chances are, your IAC has failed, or, the passages are clogged with junk. Have a look, and see what ya think.
You can remove the heat shields from the spark plugs, they just pull off of there, just not easily. If you have compressed air available, you could probably blow out most of the junk, so you can get a socket in there.
Old Jan 26, 2011 | 01:11 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Go to advance auto or wherever and get the codes read. Or you can try this and count the flashes, https://dodgeforum.com/forum/2nd-gen...code-list.html
Old Jan 26, 2011 | 03:20 PM
gilardis13's Avatar
gilardis13
Thanks for the advise I'll take a look and give a response.
Old Jan 26, 2011 | 03:21 PM
gilardis13's Avatar
gilardis13
Thanks I'll try it
Old Jan 26, 2011 | 08:12 PM
dhvaughan's Avatar
dhvaughan
yank the heat shield tubes and throw them away.
DO blow out all the crap from around the plugs before removing them or it all falls into the cylinders. DO spray them with pb-blaster for a couple of days if they are rusted in. try not to break them...
as Hey said, remove IAC from the back of the throttle body and inspect the pintle and the hole in the center of the well. if dirty, clean it out. if not dirty, replace it.
Old Feb 6, 2011 | 09:06 PM
bonesbmx's Avatar
bonesbmx
i have the same problem with no high idle. i replaced aic and tps fixed it for about 2 weeks now back to same problem. if i shut it off after driving to the store when i come back out i have to give it gas as i start for about 30 sec then its fine.
Old Feb 6, 2011 | 09:47 PM
Did you reset the PCM after you changed the sensors?
