4x4 takes long time to engage???
Old Jan 27, 2011 | 07:38 PM
bigblock79's Avatar
bigblock79
Default 4x4 takes long time to engage???
If i shift into 4x4, takes several minutes to actually engage, after ive driven it in 4x4 and want to disengage it, it stays locked in for a few minutes... any ideas?
Old Jan 27, 2011 | 07:43 PM
Mad_Scientist's Avatar
Mad_Scientist
After you shift, try putting it in reverse for a min, then shift back to drive. That usually clears it up for me. Could be a vacuum issue, as the CAD is controlled by vacuum signals from the t-case. Either the vacuum motor on the CAD is going out, or you have a drop in vacuum pressure somewhere
Old Jan 27, 2011 | 07:52 PM
Lone136's Avatar
Lone136
I have the same problem with mine. Will be getting the cable controlled Cad soon.Will know it's in gagded then
Old Jan 27, 2011 | 07:55 PM
meanwhitemopar's Avatar
meanwhitemopar
What thy said. Put it in recede, then back to drive, my truck.does it to,
Old Jan 27, 2011 | 09:14 PM
DukesOfHazzard's Avatar
DukesOfHazzard
http://www.emsoffroad.com/store/inde...roducts_id=351
Old Jan 29, 2011 | 11:56 AM
bigblock79's Avatar
bigblock79
i tried going back and forth between forward and reverse, doesnt make a difference... lost
Old Jan 29, 2011 | 12:09 PM
Mad_Scientist
I would point at a vacuum leak then, the #1 location for this to happen is the steel lines from the t case to the cad. If those are good try checking with carb cleaner
Old Jan 29, 2011 | 08:55 PM
offroadgearhead's Avatar
offroadgearhead
My truck wouldn't engage at all when I got it.
I took the CAD actuator assembly off, sprayed quite a bit of PB Blaster in the actuator itself (in each of the connections that the vacuum lines attach to), slid the fork back and forth a few times until it loosened up, and put it all back together.
Since then it will engage or disengage within a a second or two.
Old Jan 30, 2011 | 09:38 AM
Silver_Dodge's Avatar
Silver_Dodge
Mine has always engaged quickly (almost immediatly upon shifting), but disengages very slowly (up to a minute or two).
Old Jan 30, 2011 | 11:01 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Could just be the cold azz weather, how was it in the summer? Regardless, you need to check vacuum with a gauge. And said gauge (if a descent one) can also be used as a pump to check the CAD motor. If all that checks out, the problem could be anything from too thick or dirty fluid to worn shoes on the fork or bad bushings.
