brights problem
Old Feb 5, 2011 | 12:20 PM
dvowicker's Avatar
dvowicker
just sylvania ultra brights
Ground, bulb, or switch problem then.
Old Feb 5, 2011 | 12:22 PM
dvowicker's Avatar
dvowicker
alright where is the ground at do you know and i just took my buddies headlight switch and put it in mine and his didnt work in my truck either
Old Feb 5, 2011 | 12:27 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Check the bulb sockets themselves also. And you can use this for wiring, https://dodgeforum.com/forum/2nd-gen...-gen-rams.html
Old Feb 5, 2011 | 12:42 PM
dvowicker's Avatar
dvowicker
so what im seeing is that power runs through the headlight switch to the multifunction switch to the bulbs each bulb has its own ground correct?
Old Feb 5, 2011 | 01:04 PM
zman17's Avatar
zman17
I think the ground is common for both lights. Have you checked the sockets? The one by the battery may be corroded from bat acid. I'm not spending your money, but at this point, I personally would replace the MF switch. And put all the info about your truck in your sig. That FSM is for 2001, and things change slightly from year to year.
Old Feb 5, 2011 | 01:10 PM
dvowicker's Avatar
dvowicker
when you say check the sockets how would i go about doing this? id rather do that than change that switch
Old Feb 5, 2011 | 01:22 PM
Pull the bulbs, and have a look into the sockets. They can get gunked up, and cause a short.
Old Feb 5, 2011 | 01:24 PM
zman17's Avatar
zman17
Visually inspect them. An ohm meter would help too. I'm not saying it is the problem, but you have to at least eliminate the possibility.
dvowicker's Avatar
dvowicker
yah they are clean.. i hate to bring this back up but before i fixed the battery temp sensor both my headlights worked just not the brights on them
