help
Old Feb 1, 2011 | 02:13 AM
Ernie Packard's Avatar
Ernie Packard
Default help
i hope i'm doing this right.i need an answer to my question. I just replaced my engine in a 1994 1500 with a new 318 mag.replaced, plugs,wires,dist cap rotor etc. but i'm not getting fire to #2 plug or #6 plug any ideas?
Old Feb 1, 2011 | 08:42 AM
gordie580's Avatar
gordie580
You will probable have better luck going to the 2nd Generation fourm as our trucks are from 2002-2008 model issues..
Old Feb 1, 2011 | 09:13 AM
MedicNathan's Avatar
MedicNathan
Have you checked the stupid things yet? Firing order correct and Spark plugs at the correct Gap?
Old Feb 1, 2011 | 09:30 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Are you getting no spark at all or a misfire on those 2 cylinders? What brand plugs did you use? Was the distributor removed?
Old Feb 1, 2011 | 12:30 PM
Ernie Packard
it is a new long block. i use nkg plugs. no spark to eighter plug
Old Feb 1, 2011 | 12:40 PM
zman17's Avatar
zman17
Old Feb 1, 2011 | 01:23 PM
Ernie Packard
dist was removed from old engine to the new engine
Old Feb 1, 2011 | 01:30 PM
zman17's Avatar
zman17
You need to have the fuel sync reset then.
Old Feb 1, 2011 | 03:18 PM
matty675's Avatar
matty675
zman-how would you like to enlighten ALL of us on this "fuel sync" mumbo-jumbo??
im wondering how i'll set the fuel sync on my 408 stroker as well... (in other words.. how do you set fuel sync on a new longblock w/ new distributor?)
Old Feb 1, 2011 | 03:24 PM
zman17's Avatar
zman17
It may not be the OP's problem, but you need a "fuel sync" mumbo-jumbo" scanner to reset it, if the dizzy has been replaced or removed.
