replace the rocker arms
Old 02-06-2011, 03:27 PM
Silver_Dodge's Avatar
Silver_Dodge
Silver_Dodge is offline
I've never heard that either. Interesting. The OBD1 guys really should look at 1.7's then since there are no good programmers for them.
  #32
Old 02-06-2011, 03:39 PM
drewactual's Avatar
drewactual
drewactual is offline
I'm digging for reference, but all I'm finding are LA's had 1.5's with option for 1.6's.. It may be all magnums had 1.6's.. If so- I have misspoken, and all magnums are stock w/ 1.6's..
  #33
Old 02-06-2011, 03:47 PM
Silver_Dodge
That's what I thought was the case since one of the main differences between a Magnum and the older LA's was the heads.
  #34
Old 02-06-2011, 05:48 PM
BIGBIRD85's Avatar
BIGBIRD85
BIGBIRD85 is offline
the magnums have the 1.6 and the LA has 1.5. from what i have read the old 318's will not let you run the 1.7's because of the rod hitting the head issues. the valve on the piston i have never heard of.
  #35
Old 02-06-2011, 05:49 PM
Gerehead8's Avatar
Gerehead8
Gerehead8 is offline
Originally Posted by drewactual
'94 and '95 for certain used 1.5's..
What about the 91-93 Magnum 318 and 92-93 Magnum 360?
  #36
Old 02-06-2011, 06:04 PM
drewactual's Avatar
drewactual
I found where I came across that information, it is embedded the Comp Cam CamQuest application.. I swear I've heard it before though.. and I should have said pre-96 in my original post instead of 94-95.. I was wrong though, so it doesn't matter- unless you're finding it fun to drag out my humiliation lol..
LA engines used the 1.5's.. it was bad juju to use a higher ratio unless you did some head work- and if you were going to do head work you may have well of just used a different grind cam and saved some money for elsewhere, no?
Seriously though, all magnums have 1.6:1 rockers.. my bad..
  #37
Old 02-06-2011, 09:27 PM
dodgeramit_10's Avatar
dodgeramit_10
dodgeramit_10 is offline
Is there really a clearance issue with the airgap and 14x3? I'm getting my sheet ready when I get my tax returns.
  #38
Old 02-06-2011, 11:39 PM
Gerehead8's Avatar
Gerehead8
I was just pointing out the odd choice of years, thats all. A lot of people forget about the first gen magnums.
  #39
Old 02-07-2011, 11:19 AM
chastain90's Avatar
chastain90
chastain90 is offline
any one with a 2001 5.9 have these and could tell me the power difference? Trying to decide if I really want to get them or not.
  #40
Old 02-07-2011, 01:42 PM
HeyYou is offline
Dodge Forum Administrator
Received 3,396 Likes on 3,136 Posts
Its a pretty good bang for the buck mod..... I don't have 'em, yet.... but, it is part of the plan.
Quick Reply: replace the rocker arms
