starter issues
Pin 86 on the relay should be 12 volts FROM the ignition switch. Verifying that test isn't a bad plan.
Relay gets its ground thru the P/N switch.
If you aren't getting power from the switch to the relay, check circuit A41, (pin 1) in connector 1 (yellow wire) and see if that gets power when you put the switch to start. Pin 4 in connector 1 supplies power to that portion of the switch. (pink with black trace) That should be hot at all times.
Ok, pin 85 on the relay socket goes to ground. In park, or neutral, you should have zero resistance to ground. Its a black wire, with a white trace, goes to the neutral safety switch. Do you have a meter, or are you using a test light?
Yeah, chasing electrical isn't exactly my favorite passtime either....... Quite frankly, I hate it.
