transmission swap will it work?
the starters on both are on the drivers on both the V8 jeep's and the truck's
the reason the starter idea was bough up was, problem that jr has a i6 in his jeep and they have the starters on the pass side
Yes 95 was the last year of weighted torque converters. In 96 the weight moved to the flexplate.
Then the jeep didn't have a 5.2L as the oil filter would interfere with a passenger side starter. Unless I am really confused they would occupy the same area as a magnum block is a magnum block no difference on application.
The starter is on the passenger side on ALL 93-98 Grand Cherokees, regardless of the engine. This includes the 46RH used on 93-95 V8 ZJ's, the 44RE used on 96-98 5.2's, and the 46RE used behind the 5.9 in the 98 5.9L Limited.
The Jeep transmission won't work without changing to a Jeep oil pan (the Jeep starter will interfere with the Dodge on the passenger side), and moving the wiring around.
Jr. Mechanic i believe is right from everything that i saw while taking both of the transmissions out i will get the oil pan from the jeep along with the starter and it hopefully will have no problems
wow i stand corrected, just hard to belive that they would make diff lager parts like that
i helped my buddy with a rear main on his 94 zj v8, i really though it was on the driver side, i gusse im just picturing mine( when i did my rear main seal also)
ok guys new update! i got the transmission from the junk yard and swaped it in and the starter did need to be from the jeep and the oil pan did not need to be swapped. spliced in longer starter cables and it started right up and shifts perfectly!
