94 Ram 2500 stalling at a complete stop.
Old Feb 10, 2011 | 01:30 AM
gabegober's Avatar
gabegober
Default 94 Ram 2500 stalling at a complete stop.
I own a 1994 Dodge Ram 2500, 360ci, 2wd, automatic transmission. I have been having a problem with my truck stalling at a complete stop. This doesnt happen all the time. I bought the truck used a few years ago and I am not sure what type of maintenece has been done on the truck. When I came to a complete stop, I can feel the RPMs of the truck start to drop. It is like when coming to a complete stop with a manual transmission and not engaging the clutch. Can anyone give me some pointers?
Old Feb 10, 2011 | 08:05 AM
bigdaddyjr's Avatar
bigdaddyjr
sounds like your iac is either dirty or needs to be replaced do a search on how to clean it try that first if that doesn't help i'd replace it, i had a problem like yours as well stalling when coming to a stop.
Old Feb 10, 2011 | 08:42 AM
chogg's Avatar
chogg
It could also be the valve body in the trans sticking causing the trans not to shift. Check your trans fluid and see what it looks like. Easy check. If its bad tho could lead to bigger problems if not corrected fast. Dirty fluid leads to rebuild in a hurry.
Old Feb 10, 2011 | 10:03 AM
bfinley's Avatar
bfinley
i had the exact same prob it was my iac. My truck stalled every time i stoped had to keep my foot on the break and gas. Pull the iac on the back of the throttle body its probably dirty mine was just clean it up
Old Aug 20, 2011 | 06:58 PM
emerheb's Avatar
emerheb
Default Same Problem on a Diesel
Hello everyone.
I got the same problem on my 1998 RAM 2500 Cummins. I can't seem to find the IAC. Do diesel motors have it too?
Old Aug 20, 2011 | 07:55 PM
lukeca's Avatar
lukeca
I had this problem, just needed a new air filter, might wanna check that too...
Old Aug 21, 2011 | 02:30 PM
emerheb's Avatar
emerheb
I'll do that. What's weird about it though is that it stalls only when I'm on a gear (i.e. D,2,1,R). If I'm on neutral or park it doesn't do that. I'm worried it's something in the tranny.
Old Aug 21, 2011 | 03:38 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Originally Posted by emerheb
Hello everyone.
I suggest you post this question in the oil burner section.
Old Sep 13, 2011 | 09:16 PM
emerheb's Avatar
emerheb
The problem was with the torque converter...hopefully this will save you the time and $75 diagnosis it cost me
Old Sep 13, 2011 | 09:25 PM
emerheb's Avatar
emerheb
Mine was doing the same thing. It was the torque converter. Cost $75 go diagnosis, and I was quoted $805 for parts & labor but then found someone else to do it for $675. Mine is diesel so if you have ga it might be cheaper.
