Firing order
Old Feb 10, 2011 | 12:38 PM
spur_ride's Avatar
spur_ride
Default Firing order
Hey guys I'm looking for the fireing order for a 2001 1500 5.9L Thanks. Im having a heck of a time figureing out why in the heck it is back firing. Changed plugs/wires, cylinoid/wire, cap/rotor. started doing it after changing out the coil and wire.
Old Feb 10, 2011 | 12:52 PM
Gerehead8's Avatar
Gerehead8
Its cast onto the intake manifold.
Old Feb 10, 2011 | 01:00 PM
Maxx_Magnum's Avatar
Maxx_Magnum
yup, it's marked on the top of the intake manifold. But in case you can't see it, here's a diagram
Old Feb 10, 2011 | 01:04 PM
greenmachine's Avatar
greenmachine
Same as a GM if you know that
Old Feb 10, 2011 | 01:11 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
There is a TSB for routing the plug wires; otherwise, you're looking at encountering misfire issues.
Old Feb 10, 2011 | 01:30 PM
crazzywolfie's Avatar
crazzywolfie
is that actually where there number 1 spark plug wire is located on the newer distributors? i know all data has the exact same picture for my trucks but it is wrong.
Old Feb 10, 2011 | 02:08 PM
Gerehead8's Avatar
Gerehead8
Yes it is. The distributor cap on a magnum has a small one were the #1 plug wire attaches. That is a diagram of a magnum distributor cap you can tell by the different shape bolt town tabs. The LA's have metal clamps as you know. I suspect someone just used a newer diagram for alldata as the firing order is the same.
Old Mar 16, 2012 | 01:12 PM
FFFD827's Avatar
FFFD827
can some one psot the pic of the dist cap with the firing order again? im doing mine now. got the laptop set up on my truck box. or can sumone tell me where to find it in the service manual?
Old Mar 16, 2012 | 01:18 PM
01 service manual page 9-60, It's for the 5.2, but, 5.9 is the same.
Old Mar 16, 2012 | 01:20 PM
TC3EMTB's Avatar
TC3EMTB
there should be a mark or something on the cap for placement of wire #1
https://dodgeforum.com/forum/2nd-gen...on-system.html
