ARB Locker
Old Feb 15, 2011 | 04:17 PM
Pacmanloads's Avatar
Pacmanloads
Alright, went and looked at it and it is not an ARB , it is an air locker/limited slip from a jeep rubicon . Does anyone know if this will even work in my Dana 44 ? I did a little research and there are various statements . Some say it depends on if you have thick gears or not . Does this make any sense ? I'm confused .....more than ever .
Old Feb 15, 2011 | 04:30 PM
What axle does the rubicon come with?
Old Feb 15, 2011 | 04:34 PM
redneck_ram's Avatar
redneck_ram
rubicons come with dana 44's but they are totally different when compared to ours...
Old Feb 15, 2011 | 09:46 PM
penski61's Avatar
penski61
i think it depends on what year jeep , pretty sure all the new jeeps use a hybrid dana 44
easiest way to figure out if it will work is find out if the part number for that locker and see if it crosses over between the dodge dana 44 and a jeep dana but pretty sure they are different part numbers
Old Feb 15, 2011 | 09:57 PM
penski61's Avatar
penski61
also i dont think there are any air locker/ limited slip , there is an e-locker/limited slip which is an auburn ected locker
Old Feb 15, 2011 | 09:59 PM
dhvaughan's Avatar
dhvaughan
I don't see anything common here.
here's the ARB model numbers you would need for the Dodge Ram 1500 D44. you can check the application guide for whatever's in the Jeep to see if its the same number.
http://arb.com.au/media/products/air...tion_chart.pdf
RAM 1500
Front 1994-03 Dana 44 33.3 (1.31") splines 30
3.91 & UP RD116
3.73 & DN RD117
Rear 1994 on Chrysler 9.25" dia. RG splines 31
NA
JK Wrangler Rubicon
Front 2007 on replacement for 32 SPL Rock-Trac e-locker All All RD1578
Rear
(axle upgrade required - see note 8) All All RD1578
<<<< not even close to a match >>>>>
Old Feb 15, 2011 | 10:13 PM
penski61's Avatar
penski61
the OP only mentioned rubicon which came out in 03 which is why i posted it depends on what year i didnt see JK
the TJ rubicon used the same dana as the dodge but it depends on what gear ratio you have
the jk came out in 06 which had the weird dana 44
3.92+ is RD 116
3.73 and below is RD 117
