First Post! First Truck!
Old Feb 16, 2011 | 06:17 PM
MyMonkey's Avatar
MyMonkey
Default First Post! First Truck!
Ok folks. I found myself in need of a work truck to haul stuff in once in a while. Went in search of one and found a great deal on a 97 Ram 1500 SLT Laramie. 5.2 Liter. Little rough but seems to be running ok and everything works on it. I have read many helpful posts here. I look forward to learning to work on the engine. It has 151,000 miles on it. I will likely start with the seafoam treatment and either flush the tranny or remove that one way valve. (Not sure yet)
Thanks for an informative forum! I will post some pics asap but keep in mind it's a bit rough.
Old Feb 16, 2011 | 06:41 PM
UnregisteredUser's Avatar
UnregisteredUser
Welcome!
If you don't know with certainty that the transmission was serviced at 100,000 miles, you should adjust the bands and change fluid and filter straight away. Get that check valve out, too. It's not going to do you any favors.
Old Feb 16, 2011 | 08:59 PM
MyMonkey's Avatar
MyMonkey
Originally Posted by UnregisteredUser
Welcome!
I was just reading about how to change the trans fluid and tighten the bands. Think I might give it a try. Thanks!
I have no idea what service has been done to the truck so better to be safe then sorry I suppose.
Old Feb 16, 2011 | 09:20 PM
dhvaughan's Avatar
dhvaughan
welcome to df.
take a look at our FAQ's here.
https://dodgeforum.com/forum/2nd-gen-ram-faqs-143/
^^-download the 01 service manual. it'll be about 95% correct.
also see the ones at pavementsucks.
http://www.pavementsucks.com/tech.php
be careful adjusting the bands on the trans. if the trans is good, and you don't know what you're doing, then leave it alone...
Old Feb 16, 2011 | 09:52 PM
TheBigRedOne's Avatar
TheBigRedOne
Just leave the transmission alone. It will kill itself without your help.
Old Feb 16, 2011 | 10:15 PM
outlaw93z's Avatar
outlaw93z
congrats on your truck; i have a 97 1500 as well. changing the trans fluid and filter is a good idea, i did so on mine when i got it (190,000 miles) and it cleared a small slip it had right up
Old Feb 17, 2011 | 10:27 PM
MyMonkey's Avatar
MyMonkey
Well, I may take the advice of some here. I might change the fluid in the tranny but leave the bands alone. Seems a bit confusing looking at the diagram of how many turns etc. I can change the fluid there though! LOL
Thanks for the replys. Any input on the seafoam thing? Thinking of doing it in both this truck as well as my suv actually.
Old Feb 17, 2011 | 11:01 PM
MyMonkey's Avatar
MyMonkey
Forgot to add. I'm not sure that the tranny is perfect. The only thing I notice is a bit of delay and clunk when shifting into Drive. Not too bad though. Eh?
Also, thought I would look in to the plenum thing as well as the rear diff service and a tuneup.
