np231d transfer case swap help
Old Feb 18, 2011 | 02:40 PM
byronpen's Avatar
byronpen
Default np231d transfer case swap help
here is my transfer case information
231 D
5210 5022
1 10 99M2
272
He is the one im looking at, can someone tell me if it will fit
231d-HD
5210 5674 a
4 13 99nt
272
Old Feb 18, 2011 | 05:05 PM
BackwoodsRam's Avatar
BackwoodsRam
as long as the input shaft and output shaft spline counts and diameters are the same your set. the hd is just a beefier t/c then the d
Old Feb 18, 2011 | 05:07 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Some years have a different shift pattern also.
Old Feb 18, 2011 | 05:16 PM
Those both appear to be 99's. Should be the same pattern.
Old Feb 18, 2011 | 11:15 PM
byronpen's Avatar
byronpen
Just got done driving 400 miles to pick it up.will give up date tomarrow
Old Jul 22, 2011 | 12:18 AM
etdavenport's Avatar
etdavenport
Thread JACK!!!
What about swapping a 241 for a 231? my 1996 1500 just blew its case on the freeway and I found a guy that has one out of a 94 Cummins 3/4 Ton. he said hes throw me the drive line also, what would I need to swap to make it fit? I wouldn't mind the bigger case
Old Jul 22, 2011 | 03:35 PM
I think, but, am not 100% certain.... that the output shaft for the rear, is different between the two cases. The donor truck would have to be the same cab style, and bed length, for the drivshafts to swap, but, the ujoints from the shaft, to the axle are indeed different sizes between the two weight ratings. Length might be different two, as the donor truck will have heavier (larger) axles. You might be able to get away with it, or, you might not.....
If you can get the axles as well..... and the two trucks are the same style/bed length, the stronger axles WOULD make for a rather nice upgrade.
Old Jul 23, 2011 | 09:00 AM
MonteC's Avatar
MonteC
Just make sure you check the input and out put splines. The 241 maybe different.
