True Dual
Old Feb 19, 2011 | 10:41 PM
MNRAM1500's Avatar
MNRAM1500
Originally Posted by drewactual
http://www.nsxprime.com/FAQ/Miscella...austtheory.htm
pretty good article on exhaust theory..
I run a magna flow true x muffler.. gotta maximize the scavenging 'yall- back pressure is a whole other animal, and it's not good in any circumstance..
to the original poster: I run true duals.. I dig it.. everything I did to the exhaust prior to running true duals was a waste- now that said, I bet it would be near as good (for our purposes) by simply getting rid of the factory Y pipe.. that thing is a joke of some sort..
Drewactual do you recommend an x or an h pipe?
Old Feb 19, 2011 | 11:00 PM
drewactual's Avatar
drewactual
I don't know enough difference to comment on which is better.. this is my first experience with an X pipe, and I've never ran an H pipe.. I've read enough to know that you need one or the other to scavenge properly though- it has 'sumpthin to do with the trailing edge of the pulses and getting the vacuum effect enough to maintain a constant flow.
a matter of fact, the x-pipe I chose is part of a big honkin' muffler..
Old Feb 19, 2011 | 11:18 PM
Originally Posted by MNRAM1500
Could you get pics?
Unfortunately, no. I can't. He bought a new truck, and sold his second gen.....
Old Feb 20, 2011 | 02:54 AM
thetypezero's Avatar
thetypezero
Originally when i wanted to run true duals I was wanting to find a 5.9 HD exhaust cause they used 2 cats. and it should have bolted right up, Correct me If I'm wrong. Long story short I ended up going with a magnaflow highflow cat and pipes and circle track mufflers. I still wish i would have went with the 2 cat exhaust.. Reason why I wanted the stock HD exhaust is because I have to run marta every year.
