True Dual
Old Feb 19, 2011 | 04:47 PM
MNRAM1500's Avatar
MNRAM1500
Default True Dual
Ok so i finally decided on a mod. I'm going to true dual my truck instead of a y-pipe off the cat... my question is do i have to buy two identical cats or can i use the stock and a off brand? i know it will give me a check engine but one of my 02's is shot anyway so i'm not worried about it.
Old Feb 19, 2011 | 04:49 PM
Annihilator_X9's Avatar
Annihilator_X9
I'd go with two new cats. Otherwise you'll have different flow rates on each side.
Old Feb 19, 2011 | 04:58 PM
MNRAM1500's Avatar
MNRAM1500
thats what i was thinking but wasn't sure
Old Feb 19, 2011 | 04:59 PM
TwistedCage's Avatar
TwistedCage
+1 new cat for both save you time and money in the long run
Old Feb 19, 2011 | 06:42 PM
dvowicker's Avatar
dvowicker
i was told by the guy that has done all my exhaust work that our trucks run like **** with true duals. if you have them done how do u have it set up and do you have any video clips. true duals no mufflers?
Old Feb 19, 2011 | 07:30 PM
MNRAM1500's Avatar
MNRAM1500
not done yet i need money to get a couple cats.
this guy does though i love the sound
http://www.youtube.com/watch?v=F9a2e...eature=related
Old Feb 19, 2011 | 07:38 PM
Friend of mine put true duals on his truck. Just a short H pipe between the two banks. (both ran down the passenger side of the truck. H was maybe 2 inches long, with the pre-cat O2 sensor installed there.) his sounded pretty good, and ran fine.
Old Feb 19, 2011 | 07:54 PM
MNRAM1500's Avatar
MNRAM1500
Could you get pics?
Old Feb 19, 2011 | 09:23 PM
aim4squirrels's Avatar
aim4squirrels
You must run an x or h pipe on any true dual setup regardless of the vehicle type. You must balance the exhaust pulses to get it to run right. IIRC, the h pipe favors torque and the x pipe favors high end hp.
Old Feb 19, 2011 | 09:32 PM
drewactual's Avatar
drewactual
http://www.nsxprime.com/FAQ/Miscella...austtheory.htm
pretty good article on exhaust theory..
I run a magna flow true x muffler.. gotta maximize the scavenging 'yall- back pressure is a whole other animal, and it's not good in any circumstance..
to the original poster: I run true duals.. I dig it.. everything I did to the exhaust prior to running true duals was a waste- now that said, I bet it would be near as good (for our purposes) by simply getting rid of the factory Y pipe.. that thing is a joke of some sort..
