synethic vs regular?????
Old Feb 21, 2011 | 06:36 PM
  #31
96smokestack's Avatar
96smokestack
older engines (like 150k ++) run better on dino oil because the clearances aren't as tight in the oil gallies etc. In older engines I would suggest dino oil. You definetely want at least 10w as well to keep the oil pressure nice and strong.
Old Feb 21, 2011 | 06:41 PM
  #32
PurplDodge's Avatar
PurplDodge
Originally Posted by BigRedRam95
When I ran reg oil I changed the oil and filter every 3000 now with the synthetic I change the oil and filter every 6000.
Why did you extend the interval?
Old Feb 21, 2011 | 06:43 PM
  #33
BigRedRam95's Avatar
BigRedRam95
Because synthetic is not supposed to break down as fast.
Old Feb 21, 2011 | 06:51 PM
  #34
matty675's Avatar
matty675
oil galleys dont have clearances...
if you mean main and rod bearing clearances, then yes.
Old Feb 21, 2011 | 06:54 PM
  #35
CPTAFW163's Avatar
CPTAFW163
it breaks down the same rate. But here is something that DOES NOT change:
The carbon in your oil. It does not matter how well it holds its vscosity, you are still running with DIRTY oil.
If you change your oil and filter every 3 K, it does not matter what oil you use. I splurge on synthetic for preference. and 27 bucks every 3-6 months is not that bad for me.
Old Feb 21, 2011 | 06:59 PM
  #36
CPTAFW163's Avatar
CPTAFW163
Originally Posted by matty675
hmmm, interesting... id be interested to see what the rest of the engine looks like
I should have taken a pic when the intake was off. pristine. I was replacing my plenum (never checked it, just preventative maint) and the plenum was not leaky at all. I could have eaten off it. It looked like bare, dry metal. That has nothing to do with the oil though, but the motor is very clean.
i do use lucas oil stabilizer as well. Syn always runs a bit thin so I add it to thicken it up. Plus two tablespoons of lucas assembly lube (extra zinc).
Old Feb 21, 2011 | 07:10 PM
  #37
BigRedRam95
So do you think I am still ok at 6000?
Old Feb 21, 2011 | 07:21 PM
  #38
matty675's Avatar
matty675
weird how some of them get the crust, and some dont
Old Feb 21, 2011 | 07:33 PM
  #39
zman17's Avatar
zman17
Retired Moderator - RIP
Yea, the one's that go 6000 mile's between changes! LOL
Old Feb 21, 2011 | 07:35 PM
  #40
matty675's Avatar
matty675
HAHAHA amsoil claims 10,000 miles!
