Guess My Heater Core's Leaking
Old Mar 9, 2011 | 07:44 PM
  #21
DodgeRam10's Avatar
DodgeRam10
ok almost got it back together i had one of the bolts that go through the firewall come off of the box and it was a pain.anyways i remeber on this thread
https://dodgeforum.com/forum/2nd-gen...ater-core.html
on the 6th and 7th pic is the nuts that you have to take off on the inside to be able to pull the box back it says theres two but when i did it i had to remove three. now i cant remember where the 3rd was at. any ideas.thanks
Old Mar 10, 2011 | 07:48 PM
  #22
DodgeRam10's Avatar
DodgeRam10
sorry to keep buggin but i cant find the bolt coming out of the firewall on the inside that this nut threads on to. the post above has pics of two of the bolts that i already found but i had to take a third one not mentioned in the diy off and now cant fiind it again. any ideas what im talking about? this is taking me way to long to do and ive tried looking for this stupid thing longer than it took me to change the heater core.
Old Mar 10, 2011 | 08:32 PM
  #23
DodgeRam10's Avatar
DodgeRam10
anyone?
Old Mar 10, 2011 | 08:56 PM
  #24
DodgeRam10's Avatar
DodgeRam10
startin to think i should just put it back together without it.
Old Mar 10, 2011 | 11:46 PM
  #25
Even the FSM only shows two on the inside..... is that nut possibly for behind the PCM? (as it appears there are one or more nuts there too.....)
Old Mar 10, 2011 | 11:56 PM
  #26
ghost4321's Avatar
ghost4321
One of those bolts has two nuts on it, one to hold the box and one to hold a ground wire. I forget which bolt though.
Old Mar 11, 2011 | 09:27 AM
  #27
DodgeRam10's Avatar
DodgeRam10
i guess that could be and i just didnt realize the two nuts were on the same stud..that stud is right in front of the heater core.when i put it back together i just put the ground wire on the stud and tightned one nut on there but i guess the second would be so it doesnt stress the ground wire out by pulling on it?? but if your sure i will do that, cant believe i cant remember fro the life of me.
Old Mar 11, 2011 | 04:49 PM
  #28
ghost4321's Avatar
ghost4321
I'm sure there were two nuts on one stud, cause I only took one off and couldn't get the box out then I found the other nut. I think it will be fine to leave it the way it is now.
Old Mar 13, 2011 | 12:13 PM
  #29
DodgeRam10's Avatar
DodgeRam10
does anyone know where these brackets go. i think they fell down when i took the steering wheel bolts off and dropped the steering wheel. also this gold screw goes on the havc box but most of the screws are pointed and this ones flat at the tip and a little bigger around. the brackets that hold the heat core down use this screw but i have one left over and cant find where it goes.
