it's happening...
Old Feb 26, 2011 | 09:21 PM
lastrights's Avatar
lastrights
maybe try the autolight 3923 this time around ? i came from ngk and went too the autolights and seem to run better from me
Old Feb 27, 2011 | 08:41 AM
aim4squirrels's Avatar
aim4squirrels
Totally dependent on what I see from the plugs. The V powers ran well for me. I couldn't get 1000 miles out of the autolites before it was noticeably rougher on idle.
I really am leaning toward trans issues though.
Old Feb 27, 2011 | 03:51 PM
lastrights's Avatar
lastrights
how often you do WOT runs ! lol
Old Feb 27, 2011 | 04:18 PM
aim4squirrels
Honestly, haven't done one in about a year, as I haven't had any mods to "test" out.
Old Mar 8, 2011 | 07:26 PM
aim4squirrels
Little update today.
Power took another nose dive today, for an extended 2-3 seconds. Checked the gauges and the RPMs dropped about 500 and the sound of the engine bogged right down with it. My guess now is it's something other than the torque converter, as I would think that the TC unlocking would cause an RPM flare, not drop.
Perhaps the fuel pump is clogged/failing, as the truck snaps right back out of it and there's no apparent permanent lingering effects. No CELs or trans temp spikes either.
Old Mar 8, 2011 | 07:37 PM
How old are your cam and crank sensors?
Old Mar 8, 2011 | 07:57 PM
drewactual's Avatar
drewactual
Man, that could be as simple as a corroded battery cable, or fouled connection somewhere. Could be a failing coil... Its always the simple thing that baffle the smart fellas, and tough things that happen to the dummies like me.
It'd be cool if it was simple, huh? And prove my rule to boot!! :-)
UnregisteredUser's Avatar
UnregisteredUser
What was the weather like when it happened? Same as it's been for days, or suddenly different?
Old Mar 8, 2011 | 08:09 PM
drewactual's Avatar
drewactual
What's your angle unreg? Just curious... Reason I ask: I once saw a cracked dizzy cap on a LA ('86 5th avenue) that would condense moisture and make morning starts a pain- but dry out by the time it made it to the garage. It was real simple, hard to figure, and mainly because it was just after a full tune up.
Old Mar 8, 2011 | 08:20 PM
dodgeram07's Avatar
dodgeram07
i wonder if your msd box is on its way out
